Aller au contenu principal
Dell Latitude E6420 Fan Replacement
Ce dont vous avez besoin
  1. Dell Latitude E6420 Fan Replacement, Battery: étape 1, image 1 de 2 Dell Latitude E6420 Fan Replacement, Battery: étape 1, image 2 de 2
    • Push the tabs on the left and right of the battery out towards the edge of the case.
  2. Dell Latitude E6420 Fan Replacement: étape 2, image 1 de 1
    • While still pushing in the tabs, using your pinky finger, lift the battery out of the laptop.
  3. Dell Latitude E6420 Fan Replacement, CD/DVD Drive: étape 3, image 1 de 2 Dell Latitude E6420 Fan Replacement, CD/DVD Drive: étape 3, image 2 de 2
    • Push the button in on the CD/DVD drive to eject the drive.
  4. Dell Latitude E6420 Fan Replacement: étape 4, image 1 de 2 Dell Latitude E6420 Fan Replacement: étape 4, image 2 de 2
    • Slide the drive out of the laptop.
    • When removing the drive, keep it flat to prevent damage to anything inside the laptop.
  5. Dell Latitude E6420 Fan Replacement, Backplate: étape 5, image 1 de 2 Dell Latitude E6420 Fan Replacement, Backplate: étape 5, image 2 de 2
    • Using the screwdriver, remove seven 4mm Phillips #1 screws from the bottom of the laptop.
    • Using the screwdriver, remove two 9mm Phillips #00 screws from the bottom of the laptop.
  6. Dell Latitude E6420 Fan Replacement: étape 6, image 1 de 2 Dell Latitude E6420 Fan Replacement: étape 6, image 2 de 2
    • Gently lift the back plate off of the laptop making sure all of the tabs on the inside perimeter of the back plate are unhooked before lifting.
    • Be careful when removing the backplate. Lifting the backplate while the tabs are still hooked in will result in broken tabs.
  7. Dell Latitude E6420 Fan Replacement, Fan: étape 7, image 1 de 2 Dell Latitude E6420 Fan Replacement, Fan: étape 7, image 2 de 2
    • Using the screwdriver, remove four 10mm Phillips #0 spring screws from the fan assembly.
  8. Dell Latitude E6420 Fan Replacement: étape 8, image 1 de 2 Dell Latitude E6420 Fan Replacement: étape 8, image 2 de 2
    • Use the plastic opening tool to unclip the connector.
  9. Dell Latitude E6420 Fan Replacement: étape 9, image 1 de 1
    • Lift the fan out of the laptop.
4 autres ont terminé cette réparation.
Madysen Eames
Membre depuis le 02/27/18
1 528 Réputation
7 tutoriels rédigés
Équipe
UMass Dartmouth, Team S2-G3, Simcock Spring 2018 Membre de l'équipe UMass Dartmouth, Team S2-G3, Simcock Spring 2018
UMASSD-SIMCOCK-S18S2G3
3 membres
7 tutoriels rédigés
Un commentaire
very good explanatory steps. but you did not talk about the application of thermal paste for reassembly
Godwin Nwachukwu - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 12
Total : 2,105
