Aller au contenu principal
Dell Latitude E6420 Screen Replacement
Ce dont vous avez besoin
  1. Dell Latitude E6420 Screen Replacement, Battery: étape 1, image 1 de 2 Dell Latitude E6420 Screen Replacement, Battery: étape 1, image 2 de 2
    • Push the tabs on the left and right of the battery out towards the edge of the case.
  2. Dell Latitude E6420 Screen Replacement: étape 2, image 1 de 1
    • While still pushing in the tabs, using your pinky finger, lift the battery out of the laptop.
  3. Dell Latitude E6420 Screen Replacement, Screen: étape 3, image 1 de 2 Dell Latitude E6420 Screen Replacement, Screen: étape 3, image 2 de 2
    • Open the laptop and lay it flat on your work surface.
    • Using the spudger, lift the bezel up from around the laptop screen.
  4. Dell Latitude E6420 Screen Replacement: étape 4, image 1 de 3 Dell Latitude E6420 Screen Replacement: étape 4, image 2 de 3 Dell Latitude E6420 Screen Replacement: étape 4, image 3 de 3
    • Using the screwdriver, remove four 5mm Phillips #0 screws from the bottom of the laptop screen.
    • Using the screwdriver, remove two 3mm Phillips #0 screws from the top of the laptop screen.
    • Lift the screen.
  5. Dell Latitude E6420 Screen Replacement: étape 5, image 1 de 1
    • Lift the laptop screen and flip it over to lay it on top of the keyboard.
  6. Dell Latitude E6420 Screen Replacement: étape 6, image 1 de 2 Dell Latitude E6420 Screen Replacement: étape 6, image 2 de 2
    • Remove the piece of tape from the back of the LCD cable.
  7. Dell Latitude E6420 Screen Replacement: étape 7, image 1 de 2 Dell Latitude E6420 Screen Replacement: étape 7, image 2 de 2
    • Lift the piece of tape attached to the LCD cable.
    • Once the tape has lifted, gently pull back to unplug the LCD cable.
9 autres ont terminé cette réparation.
Madysen Eames
Membre depuis le 02/27/18
1 528 Réputation
7 tutoriels rédigés
Équipe
UMass Dartmouth, Team S2-G3, Simcock Spring 2018 Membre de l'équipe UMass Dartmouth, Team S2-G3, Simcock Spring 2018
UMASSD-SIMCOCK-S18S2G3
3 membres
7 tutoriels rédigés
Un commentaire
Bonjour, Merci
endibos - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 29
Total : 3,831
