Introduction
A faulty wireless card can affect wireless connection. This guide will show the user how to replace the wireless card.
Push out the tabs on the left and right of the battery with your thumbs. Push out the tabs on the left and right of the battery with your thumbs.
  • Push out the tabs on the left and right of the battery with your thumbs.
Ajouter un commentaire
While still pushing in the tabs, using your pinky finger, lift the battery out of the laptop.
  • While still pushing in the tabs, using your pinky finger, lift the battery out of the laptop.
Push the button in on the CD/DVD drive to eject the drive. Push the button in on the CD/DVD drive to eject the drive.
  • Push the button in on the CD/DVD drive to eject the drive.
Slide the drive out of the laptop. When removing the drive, keep it flat to prevent damage to anything inside the laptop.
  • Slide the drive out of the laptop.
  • When removing the drive, keep it flat to prevent damage to anything inside the laptop.
Using the screwdriver, remove seven 4mm Phillips #1 screws from the bottom of the laptop. Using the screwdriver, remove two 9mm Phillips #00 screws from the bottom of the laptop.
  • Using the screwdriver, remove seven 4mm Phillips #1 screws from the bottom of the laptop.
  • Using the screwdriver, remove two 9mm Phillips #00 screws from the bottom of the laptop.
Gently lift the back plate off of the laptop making sure all of the tabs on the inside perimeter of the back plate are unhooked before lifting. Be careful when removing the backplate. Lifting the backplate while the tabs are still hooked in will result in broken tabs.
  • Gently lift the back plate off of the laptop making sure all of the tabs on the inside perimeter of the back plate are unhooked before lifting.
  • Be careful when removing the backplate. Lifting the backplate while the tabs are still hooked in will result in broken tabs.
Using the screwdriver, remove two 4mm  JIS #0 screws. Using the screwdriver, remove two 4mm  JIS #0 screws.
  • Using the screwdriver, remove two 4mm JIS #0 screws.
Disconnect 4 wires by pulling upward. Gently remove the wires to prevent damaging them. Gently remove the wires to prevent damaging them.
  • Disconnect 4 wires by pulling upward.
  • Gently remove the wires to prevent damaging them.
Lift the wiring harness out of the way.
  • Lift the wiring harness out of the way.
The card will lift up, remove the card by pulling the lifted edge away from you. The card will lift up, remove the card by pulling the lifted edge away from you. The card will lift up, remove the card by pulling the lifted edge away from you.
  • The card will lift up, remove the card by pulling the lifted edge away from you.
Madysen Eames
Membre depuis le 27/02/2018
855 Réputation
7 tutoriels rédigés
Équipe
UMass Dartmouth, Team S2-G3, Simcock Spring 2018 Membre de l'équipe UMass Dartmouth, Team S2-G3, Simcock Spring 2018
UMASSD-SIMCOCK-S18S2G3
3 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 12
Total : 33
