Introduction
Follow this guide in order to replace the hard drive to your Dell Latitude E6510.
Pièces
Aucune pièce nécessaire.
Unlock the two latches on the back by sliding them inwards.
  • Unlock the two latches on the back by sliding them inwards.
Ajouter un commentaire
Slide the battery out from the laptop. Slide the battery out from the laptop.
  • Slide the battery out from the laptop.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
After removing the battery, unscrew the four 3 mm screws on the back plate using a Phillips #1 screwdriver. The back plate does not need to be removed. Removed only for a clear view.
  • After removing the battery, unscrew the four 3 mm screws on the back plate using a Phillips #1 screwdriver.
  • The back plate does not need to be removed. Removed only for a clear view.
The hard drive should slide out of the laptop. However, if not, use a spudger to pry the hard drive out of the laptop. The hard drive should slide out of the laptop. However, if not, use a spudger to pry the hard drive out of the laptop.
  • The hard drive should slide out of the laptop. However, if not, use a spudger to pry the hard drive out of the laptop.
Kolin Doyle
Membre depuis le 06/11/2017
419 Réputation
4 tutoriels rédigés
Équipe
Baylor, Team S8-G4, Johnson Fall 2017 Membre de l'équipe Baylor, Team S8-G4, Johnson Fall 2017
BU-JOHNSON-F17S8G4
1 membre
4 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 36
Total : 302
