Pièces
Aucune pièce nécessaire.
Remove the four 4-mm screws on the bottom of the laptop using a #0 screw driver.
  • Remove the four 4-mm screws on the bottom of the laptop using a #0 screw driver.
Ajouter un commentaire
Carefully turn the laptop over and open the screen all the way. Locate the slot to remove the keyboard in the lower left hand corner.
  • Carefully turn the laptop over and open the screen all the way.
  • Locate the slot to remove the keyboard in the lower left hand corner.
  • Using a spudger as a lever, insert it into the slot and gently pry up.
After the keyboard pops up, pull it away from the screen just enough to release the tabs.
  • After the keyboard pops up, pull it away from the screen just enough to release the tabs.
  • Don’t pull the keyboard out forcefully as there is still a ribbon attached to the laptop.
Unlock the ZIF connector on the computer by pushing the two outside tabs toward the screen.
  • Unlock the ZIF connector on the computer by pushing the two outside tabs toward the screen.
Remove the flexible ribbon from ZIF connector.
  • Remove the flexible ribbon from ZIF connector.
  • Do not pull on the ribbon to remove it from the ZIF connector.
Jacob Egorov
Membre depuis le 20/01/2012
1 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 11-20, Maness Winter 2012 Membre de l'équipe Cal Poly, Team 11-20, Maness Winter 2012
CPSU-MANESS-W12S11G20
4 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 5
Total : 1,096
