Aller au contenu principal
Dell Latitude X300 Screen Replacement
Ce dont vous avez besoin
  1. Dell Latitude X300 Screen Replacement, Screen: étape 1, image 1 de 1
    • Make sure the Dell Latitude X300 power is off.
    • Remove the battery located on the bottom of the device by pushing in both clips.
  2. Dell Latitude X300 Screen Replacement: étape 2, image 1 de 2 Dell Latitude X300 Screen Replacement: étape 2, image 2 de 2
    • Remove rubber caps on each corner of the front screen with a pinch.
    • Remove the 4 mm screws located on the front screen of the laptop.
  3. Dell Latitude X300 Screen Replacement: étape 3, image 1 de 1
    • Carefully, remove the screen casing using either your hands or a proper tool.
    • The casing is very flimsy, so extreme care is required.
  4. Dell Latitude X300 Screen Replacement: étape 4, image 1 de 1
    • Remove the 4 mm screws on the bottom left and bottom right corner of the screen.
  5. Dell Latitude X300 Screen Replacement: étape 5, image 1 de 2 Dell Latitude X300 Screen Replacement: étape 5, image 2 de 2
    • Carefully lift the screen and place it on it's face.
    • Disconnect the wiring attached to the screen.
    • It is important not to damage this wire.
3 autres ont terminé cette réparation.
Jacob
Membre depuis le 03/12/14
9 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 6-1, Vijaybhaskar Spring 2014 Membre de l'équipe UMass Dartmouth, Team 6-1, Vijaybhaskar Spring 2014
UMASSD-VIJAYBHASKAR-S14S6G1
4 membres
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 5
Total : 708
