Aller au contenu principal
Dell OptiPlex GX260 Power Supply Replacement
Ce dont vous avez besoin
  1. Dell OptiPlex GX260 Power Supply Replacement, Case: étape 1, image 1 de 2 Dell OptiPlex GX260 Power Supply Replacement, Case: étape 1, image 2 de 2
    • Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
    • Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
    • Note: Some force may be required to push in the oval buttons open the PC case.
  2. Dell OptiPlex GX260 Power Supply Replacement, Power Supply: étape 2, image 1 de 1
    • Locate the power supply in the case.
    • Disconnect the AXT power cable to the motherboard.
    • Disconnect the P4 12 volt power cable from the motherboard.
    • Disconnect the power cable from the optical drive.
    • Disconnect the floppy drive power cable.
    • Disconnect the hard drive power cable.
  3. Dell OptiPlex GX260 Power Supply Replacement: étape 3, image 1 de 1
    • Remove the two Phillip screws holding the power supply into the the case and lift the power supply out.
    • When installing a new power supply ensure that the voltage selector is correctly set before you connect the mains cable.
    • Incorrect voltage settings will damage the power supply and may also cause other components to be damaged.
  4. Dell OptiPlex GX260 Power Supply Replacement: étape 4, image 1 de 1
    • Push down on the green tab with one hand.
    • With your other hand, grip the top of the power supply and pull back and up to remove from the case.
6 autres ont terminé cette réparation.
Kevin Schapansky
Membre depuis le 10/05/10
1 457 Réputation
9 tutoriels rédigés
Équipe
Cal Poly, Team 4-48, Amido Fall 2010 Membre de l'équipe Cal Poly, Team 4-48, Amido Fall 2010
CPSU-AMIDO-F10S4G48
4 membres
27 tutoriels rédigés
Un commentaire
In mine, the power supply was much longer due to a fan located on the front end. Same basic disassembly, however. There was a green tab at the front and it was difficult, but the power supply (with effort) did slide forward and out.
jknox - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 22
Total : 13,131
