Introduction
This guide will help you remove the hard drive for replacement.
Outils
Aucun outil requis.
Pièces
Aucune pièce nécessaire.
Pull the tab and the lid will pop up. Pull the tab and the lid will pop up.
  • Pull the tab and the lid will pop up.
Ajouter un commentaire
Grab the lid and pull it up and off. Grab the lid and pull it up and off.
  • Grab the lid and pull it up and off.
Pull out both sets of cables from the side of the optical drive. Both cables are plugged into the drive right next to each other.
  • Pull out both sets of cables from the side of the optical drive.
  • Both cables are plugged into the drive right next to each other.
Pull the tab up holding the optical drive in place. Slide the optical drive out.
  • Pull the tab up holding the optical drive in place.
  • Slide the optical drive out.
Rotate the computer 180 degrees. Pull the metal tab up. Pull the tray away from the case.
  • Rotate the computer 180 degrees.
  • Pull the metal tab up.
  • Pull the tray away from the case.
Pinch the 2 small blue tabs towards each other. Push the large blue tab into the hard drive and push the hard drive away from the tower wall. Lift the hard drive from the case after it comes loose.
  • Pinch the 2 small blue tabs towards each other.
  • Push the large blue tab into the hard drive and push the hard drive away from the tower wall.
  • Lift the hard drive from the case after it comes loose.
Pull out both bundles of wires connected to the hard drive. Flip the hard drive so that the blue case is facing down, and the marked tabs are facing toward you.
  • Pull out both bundles of wires connected to the hard drive.
  • Flip the hard drive so that the blue case is facing down, and the marked tabs are facing toward you.
Pull the 2 blue tabs away from the hard drive and then pull the hard drive case down. Pull the 2 blue tabs away from the hard drive and then pull the hard drive case down. Pull the 2 blue tabs away from the hard drive and then pull the hard drive case down.
  • Pull the 2 blue tabs away from the hard drive and then pull the hard drive case down.
12 autre(s) ont terminé cette réparation.
Rebecca Harrison
Membre depuis le 29/09/2014
386 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 13-10, Forte Fall 2014 Membre de l'équipe Cal Poly, Team 13-10, Forte Fall 2014
CPSU-FORTE-F14S13G10
6 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 4
7 derniers jours : 20
30 derniers jours : 90
Total : 4,217
