Introduction
This guide will teach you how to replace the RAM within your computer.
Outils
Aucun outil requis.
Pièces
Aucune pièce nécessaire.
Pull the tab and the lid will pop up. Pull the tab and the lid will pop up.
  • Pull the tab and the lid will pop up.
Ajouter un commentaire
Grab the lid and pull it up and off. Grab the lid and pull it up and off.
  • Grab the lid and pull it up and off.
Pull out both sets of cables from the side of the optical drive. Both cables are plugged into the drive right next to each other.
  • Pull out both sets of cables from the side of the optical drive.
  • Both cables are plugged into the drive right next to each other.
Pull the tab up holding the optical drive in place. Slide the optical drive out.
  • Pull the tab up holding the optical drive in place.
  • Slide the optical drive out.
Press down on the white tabs on both sides of the RAM stick until the RAM stick pops up. Press down on the white tabs on both sides of the RAM stick until the RAM stick pops up.
  • Press down on the white tabs on both sides of the RAM stick until the RAM stick pops up.
Gently lift the RAM stick up and out of the case.
  • Gently lift the RAM stick up and out of the case.
  • When inserting a RAM stick, press firmly down into the slot until the white tabs lock into both sides of the stick.
6 autre(s) ont terminé cette réparation.
Brandon Cooper
Membre depuis le 28/09/2014
387 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 13-10, Forte Fall 2014 Membre de l'équipe Cal Poly, Team 13-10, Forte Fall 2014
CPSU-FORTE-F14S13G10
6 membres
6 tutoriels rédigés
Dell master. I'm going to be the best repair pro on this side of the south side.
fixitbrosmsus - Réponse
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 7
Total : 937
