Introduction
This guide will show you how to remove the CPU heat sink.
Outils
Aucun outil requis.
Pièces
Aucune pièce nécessaire.
Make sure to shut down the computer! you can do this by going to the start menu and clicking shutdown.
  • Make sure to shut down the computer! you can do this by going to the start menu and clicking shutdown.
  • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
Ajouter un commentaire
Lay the computer on its side; you will see a blue knob. Turn said knob 90 degrees counter clockwise.
  • Lay the computer on its side; you will see a blue knob. Turn said knob 90 degrees counter clockwise.
Slide the panel case forward about 1/2 inch while knob is turned.
  • Slide the panel case forward about 1/2 inch while knob is turned.
  • Lift panel case off computer.
Remove the blue shield by sliding it straight upwards. Remove the blue shield by sliding it straight upwards.
  • Remove the blue shield by sliding it straight upwards.
Pull back on the tab nearest to the front case fan. Slide the CPU heat sink from under the clip and pull upward. You may need to twist the CPU heat sink side to side to free it from the thermal paste.
  • Pull back on the tab nearest to the front case fan.
  • Slide the CPU heat sink from under the clip and pull upward.
  • You may need to twist the CPU heat sink side to side to free it from the thermal paste.
To reassemble your device, follow these instructions in reverse order. Don't forget to reapply thermal compound when reinstalling the heat sink.
donnavon
Membre depuis le 02/09/2014
707 Réputation
7 tutoriels rédigés
Équipe
Pasco Hernando, Team 1-1, Prince Fall 2014 Membre de l'équipe Pasco Hernando, Team 1-1, Prince Fall 2014
PHSC-PRINCE-F14S1G1
11 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 15
Total : 483
