Introduction
This PCI network adapter enables users to connect to the internet typically though an Ethernet cable. You will not be able to obtain a connection if this device is faulty.
Outils
Aucun outil requis.
Pièces
Aucune pièce nécessaire.
Power down your PC and remove the power cord from the back. Power down your PC and remove the power cord from the back.
  • Power down your PC and remove the power cord from the back.
Ajouter un commentaire
Press and hold the power button for about 10 seconds, then release. This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
  • Press and hold the power button for about 10 seconds, then release.
    • This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
With the computer standing upright, firmly pull on the tab at the back of the computer.
  • With the computer standing upright, firmly pull on the tab at the back of the computer.
  • When the side panel pops free, gently pull the panel away from the computer.
  • If you have trouble freeing the side panel from the case, you may need to pull the tab a bit harder.
Gently push the release tab on the card retention latch from the inside to pivot the latch open. The latch will remain in the open position Gently push the release tab on the card retention latch from the inside to pivot the latch open. The latch will remain in the open position
  • Gently push the release tab on the card retention latch from the inside to pivot the latch open. The latch will remain in the open position
With your free hand, gently squeeze the sides of the card. Pull upwards to release it from the tab slots that hold it in place.
  • With your free hand, gently squeeze the sides of the card. Pull upwards to release it from the tab slots that hold it in place.
Kristina
Membre depuis le 03/09/2014
141 Réputation
8 tutoriels rédigés
Équipe
Pasco Hernando, Team 5-1, Prince Fall 2014 Membre de l'équipe Pasco Hernando, Team 5-1, Prince Fall 2014
PHSC-PRINCE-F14S5G1
10 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 16
Total : 1,163
