Introduction
Remove and Replace the Hard Drive
Outils
Aucun outil requis.
Pièces
Aucune pièce nécessaire.
Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
  • Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
  • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
Ajouter un commentaire
Lay the computer on its side; you will see a blue knob. Turn this knob 90 deg clockwise.
  • Lay the computer on its side; you will see a blue knob.
  • Turn this knob 90 deg clockwise.
Slide the panel case forward about 1/2 inch while knob is turned. Lift panel case off computer.
  • Slide the panel case forward about 1/2 inch while knob is turned.
  • Lift panel case off computer.
Unplug the blue cable that connects the hard drive to the motherboard. Unplug the blue cable that connects the hard drive to the motherboard.
  • Unplug the blue cable that connects the hard drive to the motherboard.
Unplug the power supply, distinguished by its red and yellow wires (yellow wire obscured from view). Unplug the power supply, distinguished by its red and yellow wires (yellow wire obscured from view).
  • Unplug the power supply, distinguished by its red and yellow wires (yellow wire obscured from view).
Squeeze the release tabs on either side of the hard drive.
  • Squeeze the release tabs on either side of the hard drive.
Slide the Hard Drive out while squeezing the tabs. Slide the Hard Drive out while squeezing the tabs.
  • Slide the Hard Drive out while squeezing the tabs.
6 autre(s) ont terminé cette réparation.
Wyatt
Membre depuis le 06/10/2010
742 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 22-4, Maness Fall 2010 Membre de l'équipe Cal Poly, Team 22-4, Maness Fall 2010
CPSU-MANESS-F10S22G4
4 membres
13 tutoriels rédigés
Thanks for great tutorial.
Politers - Réponse
Yeah great tutorial!
Rebinas - Réponse
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 15
Total : 5,345
