Introduction
Follow these steps to install a cooling fan.
Pièces
Aucune pièce nécessaire.
Rotate the photo printer so that the bottom of the case faces upward.
  • Rotate the photo printer so that the bottom of the case faces upward.
Ajouter un commentaire
Use a Phillips #2 screwdriver to remove the three 5.65 mm screws on the bottom panel of the case in a counter-clockwise fashion.
  • Use a Phillips #2 screwdriver to remove the three 5.65 mm screws on the bottom panel of the case in a counter-clockwise fashion.
Rotate the device so that it is upright again. Under the LCD Panel there is a 9.62 mm screw, unscrew using a Phillips #2 screwdriver.
  • Rotate the device so that it is upright again. Under the LCD Panel there is a 9.62 mm screw, unscrew using a Phillips #2 screwdriver.
Remove the back panel of the case by pulling directly back.
  • Remove the back panel of the case by pulling directly back.
    • Some carefully applied force may be required to remove this part.
Rotate the photo printer so that the bottom panel faces up once again. Now lift off the bottom panel of the case to access all internal components.
  • Rotate the photo printer so that the bottom panel faces up once again. Now lift off the bottom panel of the case to access all internal components.
Finally remove the side panel with the ink-cartridge door by holding the right side  and pulling backwards with the left side. Caution! The side panel is held in by tabs; don't break these.
  • Finally remove the side panel with the ink-cartridge door by holding the right side and pulling backwards with the left side.
    • Caution! The side panel is held in by tabs; don't break these.
Carefully remove the inner components of the device by lifting the inner components up and out of the casing.
  • Carefully remove the inner components of the device by lifting the inner components up and out of the casing.
Locate the red and black cable that is connecting the fan to the top of the logic board.
  • Locate the red and black cable that is connecting the fan to the top of the logic board.
Carefully, remove the red and black cable from the logic board by pulling gently in order to isolate the cooling fan from the device.
  • Carefully, remove the red and black cable from the logic board by pulling gently in order to isolate the cooling fan from the device.
Alena Raymond
Membre depuis le 02/04/2012
25 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 14-7, Forte Spring 2012 Membre de l'équipe Cal Poly, Team 14-7, Forte Spring 2012
CPSU-FORTE-S12S14G7
4 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 429
