Aller au contenu principal
Dell Precision 5520 Hard Drive Replacement
Ce dont vous avez besoin
  1. Dell Precision 5520 Hard Drive Replacement, Base Cover: étape 1, image 1 de 2 Dell Precision 5520 Hard Drive Replacement, Base Cover: étape 1, image 2 de 2
    • Be sure to power off and unplug your device before you begin your repair.
    • Turn the system badge flap over (1) and then remove the ten M2x3 screws that secure the base cover to the computer (2).
    • Pry the edges of the base cover and lift it to remove it from the computer.
    • NOTE: Use a Torx #5 screwdriver for the base screws and a Phillips screwdriver for the two M2x8 screws inside the badge flap.
  2. Dell Precision 5520 Hard Drive Replacement, Battery: étape 2, image 1 de 1
    • Disconnect the battery cable from the system board [1].
    • Remove the seven M2x4 screws that secure the battery to the computer [2].
    • Lift the battery off the computer [3].
    • Do not apply pressure to the surface of the battery
    • Do not bend
    • Do not use tools of any kind to pry on or against the battery
    • If a battery cannot be removed within the constraints above, please contact Dell technical support
  3. Dell Precision 5520 Hard Drive Replacement, Hard Drive: étape 3, image 1 de 1
    • Remove the four M2x4 screws securing the hard-drive bracket to the computer [1].
    • Lift the hard-drive cage [2] off the hard drive assembly [3].
  4. Dell Precision 5520 Hard Drive Replacement: étape 4, image 1 de 1
    • Disconnect the hard-drive cable from the system board [1].
    • Lift the hard drive off the palm rest assembly [2].
  5. Dell Precision 5520 Hard Drive Replacement: étape 5, image 1 de 1
    • Disconnect the hard drive interposer from the hard drive assembly and then remove the hard drive covers away from the hard drive.
4 autres ont terminé cette réparation.
Johnathan Hammond
Membre depuis le 02/28/18
44 830 Réputation
408 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 11
30 derniers jours : 63
Total : 7,295
