Aller au contenu principal
Dell Precision 7510 Memory Module Replacement
Ce dont vous avez besoin
  1. Dell Precision 7510 Memory Module Replacement, Removing the Battery Cover: étape 1, image 1 de 1
    • Slide the release latch to unlock the battery cover.
    • Slide and lift the battery cover to remove it from the computer.
  2. Dell Precision 7510 Memory Module Replacement, Removing the Battery Cover: étape 2, image 1 de 1
  3. Dell Precision 7510 Memory Module Replacement, Removing the Hard Drive: étape 3, image 1 de 1
    • Remove the screws that secure the hard drive to the computer.
    • Lift the hard-drive latch to the unlock position.
    • Slide and lift the hard drive from the computer.
  4. Dell Precision 7510 Memory Module Replacement, Remove the Screws: étape 4, image 1 de 1
    • Remove the screws that secure the hard drive. Lift the hard drive away from the bracket.
  5. Dell Precision 7510 Memory Module Replacement, Removing the Keyboard Cables: étape 5, image 1 de 1
    • Peel the tape to access the cable.
    • Lift the tab and disconnect the keyboard cables from the system board.
  6. Dell Precision 7510 Memory Module Replacement, Removing the Keyboard: étape 6, image 1 de 1
    • Pry the keyboard trim starting from bottom and work along the top edge and remove it away from the computer.
    • Remove the screws that secure the keyboard to the computer.
    • Lift the front side and slide the keyboard to remove it away from the computer.
  7. Dell Precision 7510 Memory Module Replacement, Removing the Memory Module: étape 7, image 1 de 1
    • Remove the screw that secures the memory shield to the computer.
    • Lift and remove the memory shield from the computer.
    • Pry the retention clips away from the memory module until it pops up.
    • Lift the memory module and remove it from the computer.
  8. Dell Precision 7510 Memory Module Replacement, Removing the Memory Module: étape 8, image 1 de 1
    • Pry the retention clips away from the primary memory until it pops up.
    • Lift the primary memory and remove it from the computer.
Ligne d'arrivée
2 autres ont terminé cette réparation.
Johnathan Hammond
Membre depuis le 02/28/18
44 830 Réputation
408 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 985 tutoriels rédigés
Un commentaire
Thanks Johnathan. Step 4 is unnecessary.
Joseph R. Scandora - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 14
30 derniers jours : 69
Total : 10,496
