Aller au contenu principal
Dell Precision 7710 Memory Module Replacement
Ce dont vous avez besoin
  1. Dell Precision 7710 Memory Module Replacement, Battery Cover: étape 1, image 1 de 1
    • Slide the release latch to unlock the battery cover [1].
    • Slide and lift the battery cover to remove it from the computer [2].
  2. Dell Precision 7710 Memory Module Replacement, Battery: étape 2, image 1 de 1
    • Slide the release latch to unlock the battery [1].
    • Lift and remove the battery from the computer [2].
  3. Dell Precision 7710 Memory Module Replacement, Base Cover: étape 3, image 1 de 1
    • Remove the screws that secure the base cover to the computer [1].
    • Slide and lift the base cover away from the computer [2].
  4. Dell Precision 7710 Memory Module Replacement, KeyBoard: étape 4, image 1 de 2 Dell Precision 7710 Memory Module Replacement, KeyBoard: étape 4, image 2 de 2
    • Lift the tab and disconnect the 4 cables, one of the cables may be obstructed by the HDD, so you will need to unscrew/detatch the HDD tray first [1, 2].
    • Pry the keyboard trim starting from the bottom and work along the top edge and remove it from the computer.
  5. Dell Precision 7710 Memory Module Replacement: étape 5, image 1 de 1
    • Remove the screws that secure the keyboard to the computer [1].
    • Lift the front side and slide the keyboard to remove it away from the computer [2, 3].
  6. Dell Precision 7710 Memory Module Replacement, Memory Module: étape 6, image 1 de 1
    • Pry the retention clips away from the primary memory until it pops up.
    • Lift the primary memory and remove it from the computer.
  7. Dell Precision 7710 Memory Module Replacement: étape 7, image 1 de 1
    • Remove the screw that secures the memory shield to the computer [1].
    • Lift and remove the memory shield from the computer [2].
    • Pry the retention clips away from the memory module until it pops up [3].
    • Lift the memory module and remove it from the computer [4].
Johnathan Hammond
Membre depuis le 02/28/18
44 830 Réputation
408 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 14
Total : 1,679
