Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Dell Precision M6600 LCD Replacement
Ce dont vous avez besoin
  1. Dell Precision M6600 LCD Replacement, LCD: étape 1, image 1 de 1
    • Open the laptop lid fully and place it on a stable surface to access the screen.
    • Make sure the laptop is unplugged and the battery is removed to prevent electrical hazards.
  2. Dell Precision M6600 LCD Replacement: étape 2, image 1 de 2 Dell Precision M6600 LCD Replacement: étape 2, image 2 de 2
    • Use the iFixit opening tool to carefully pry around the edges of the screen bezel, starting from a corner or along the bottom edge. Gently work around the perimeter to release each of the clips.
    • Once it has been loosened, lift the bezel away from the display and set it aside in a safe place to prevent any damage.
  3. Dell Precision M6600 LCD Replacement: étape 3, image 1 de 1
    • Use a Phillips #0 screwdriver to remove the screws securing the LCD screen to the display frame.
    • Once all screws are removed, set them aside in a safe place.
  4. Dell Precision M6600 LCD Replacement: étape 4, image 1 de 1
    • Carefully disconnect the gold LCD cable from the back of the screen by gently pulling on only the connector, not the cable itself.
    • LCD connectors are fragile. apply gentle, even pressure when disconnecting to avoid bending or breaking the pins.
    • Once the cable is fully detached, lift the LCD screen out of the display assembly and place it on a clean, flat surface to prevent scratches or damage.
Kaley lindsay
Membre depuis le 03/23/18
600 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S8-G3, Valliere Spring 2018 Membre de l'équipe UMass Dartmouth, Team S8-G3, Valliere Spring 2018
UMASSD-VALLIERE-S18S8G3
2 membres
4 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 5
30 derniers jours : 25
Total : 1,233
