Pièces
Aucune pièce nécessaire.
Slide the battery release latch until it clicks into place.
  • Slide the battery release latch until it clicks into place.
  • Slide the battery out of the battery bay.
Ajouter un commentaire
Turn the computer over and open the display.
  • Turn the computer over and open the display.
  • Ease the keyboard surround up using your fingers or a plastic scribe.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Lift the keyboard surround off the computer.
  • Lift the keyboard surround off the computer.
  • Remove the two screws at the top of the keyboard.
  • CAUTION: The keycaps on the keyboard are fragile, easily dislodged, and time-consuming to replace. Be careful when removing and handling the keyboard.
  • Carefully slide the keyboard out of the computer and turn it over as indicated in the following illustration.
  • CAUTION: Be extremely careful when removing and handling the keyboard. Failure to do so could result in scratching the display panel.
Release the keyboard cable connector latch and disconnect the keyboard cable from the system board connector.
  • Release the keyboard cable connector latch and disconnect the keyboard cable from the system board connector.
  • For backlit keyboards, release the keyboard backlight cable connector latch to disconnect the keyboard backlight cable from the system board connector.
  • Lift the keyboard off the computer.
Remove the four screws securing the hard drive assembly to the computer base.
  • Remove the four screws securing the hard drive assembly to the computer base.
  • Pull the black pull-tab to lift the hard drive assembly out of the computer base and disconnect the interposer from the SATA connector on the system board.
Remove the four screws securing the hard drive cage to the hard drive.
  • Remove the four screws securing the hard drive cage to the hard drive.
  • Pull the interposer to disconnect it from the hard drive.
  • Lift the hard drive off the hard drive cage.
Johnathan Hammond
Membre depuis le 28/02/2018
33 511 Réputation
412 tutoriels rédigés
Équipe
Informative Technologies Inc. Membre de l'équipe Informative Technologies Inc.
Community
15 membres
857 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 4
Total : 16
