Aller au contenu principal
Dell Studio 1737 Keyboard Replacement
Ce dont vous avez besoin
  1. Dell Studio 1737 Keyboard Replacement, Battery: étape 1, image 1 de 2 Dell Studio 1737 Keyboard Replacement, Battery: étape 1, image 2 de 2
    • Slide the battery release slider all the way to the right and push the battery straight out of the back of the computer
  2. Dell Studio 1737 Keyboard Replacement, Keyboard: étape 2, image 1 de 1
    • Use a plastic opening tool to detach the internal clips (marked with red boxes in photo) and release the small plastic panel above the keyboard
    • This panel doesn't come off just yet, this step is just to make it easier when it comes time to remove it
  3. Dell Studio 1737 Keyboard Replacement: étape 3, image 1 de 1
    • Remove the 4mm ph1 screw under the battery
  4. Dell Studio 1737 Keyboard Replacement: étape 4, image 1 de 3 Dell Studio 1737 Keyboard Replacement: étape 4, image 2 de 3 Dell Studio 1737 Keyboard Replacement: étape 4, image 3 de 3
    • Pry black panel away from laptop body starting at the base of the screen
    • Be careful when flipping the panel over, as the panel is still attached by the fragile ribbon cable
    • Flip the panel over onto the keyboard
    • Detach the ribbon cable from the motherboard as shown
  5. Dell Studio 1737 Keyboard Replacement: étape 5, image 1 de 1
    • Starting at the top where you just removed the black panel, pry the black bezel away from the outside of the keyboard
  6. Dell Studio 1737 Keyboard Replacement: étape 6, image 1 de 2 Dell Studio 1737 Keyboard Replacement: étape 6, image 2 de 2
    • Use a small screwdriver to take out the 4 4mm ph1 screws along the top of the keyboard
    • Lift from the top of the keyboard and flip it over onto the palmrest
    • Again, be very careful of the ribbon cable attaching it, as these are easily damaged
  7. Dell Studio 1737 Keyboard Replacement: étape 7, image 1 de 2 Dell Studio 1737 Keyboard Replacement: étape 7, image 2 de 2
    • Remove the ribbon cable as shown
2 autres ont terminé cette réparation.
Joseph Jacavone
Membre depuis le 03/10/17
785 Réputation
6 tutoriels rédigés
Équipe
UMass Dartmouth, Team S8-G4, Catania Spring 2017 Membre de l'équipe UMass Dartmouth, Team S8-G4, Catania Spring 2017
UMASSD-CATANIA-S17S8G4
3 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 3
30 derniers jours : 10
Total : 694
