Pièces
Aucune pièce nécessaire.
Slide the battery lock latch on the left away from the battery.
  • Slide the battery lock latch on the left away from the battery.
Ajouter un commentaire
Slide the battery latch at the center toward the right..
  • Slide the battery latch at the center toward the right..
Slide the battery itself toward the back of the computer and remove
  • Slide the battery itself toward the back of the computer and remove
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Loosen the two captive screws on the access panel.
  • Loosen the two captive screws on the access panel.
Lift the right side of the access panel.
  • Lift the right side of the access panel.
  • Remove the access panel.
Using your fingertips, carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
  • Using your fingertips, carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
Remove the memory module from the socket
  • Remove the memory module from the socket
Johnathan Hammond
Membre depuis le 28/02/2018
33 511 Réputation
412 tutoriels rédigés
Équipe
Informative Technologies Inc. Membre de l'équipe Informative Technologies Inc.
Community
15 membres
857 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 5
