Introduction
If your laptop runs out of space, you can replace the Hard Drive with one that has a larger capacity. This guide will show you how to easily replace the Hard Drive on a Dell Vostro 1700.
Pièces
Aucune pièce nécessaire.
Remove the two 4.5mm Phillips #1 Screws that hold the HDD cover in place. Remove the two 4.5mm Phillips #1 Screws that hold the HDD cover in place.
  • Remove the two 4.5mm Phillips #1 Screws that hold the HDD cover in place.
Ajouter un commentaire
Lift the cover up and remove it. Lift the cover up and remove it.
  • Lift the cover up and remove it.
Kits de RAM Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits de RAM Mac
Obtenez plus de mémoire sur votre Mac.
Remove the 4 Phillips #0 screws that hold the HDD chassis in place. Remove the 4 Phillips #0 screws that hold the HDD chassis in place.
  • Remove the 4 Phillips #0 screws that hold the HDD chassis in place.
Lift and remove the Hard Drive and chassis out of its the slot. Lift and remove the Hard Drive and chassis out of its the slot.
  • Lift and remove the Hard Drive and chassis out of its the slot.
Nathan Valm
Membre depuis le 20/03/2018
651 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team S3-G1, Peak Spring 2018 Membre de l'équipe UMass Dartmouth, Team S3-G1, Peak Spring 2018
UMASSD-PEAK-S18S3G1
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 6
