Introduction
This quick and easy guide will show you how to remove and replace the keyboard on a Dell Vostro 1700 Laptop.
Pièces
Aucune pièce nécessaire.
Use the Plastic Opening Tools to pry off the tab located on  the right side of the top face plate. Use the Plastic Opening Tools to pry off the tab located on  the right side of the top face plate. Use the Plastic Opening Tools to pry off the tab located on  the right side of the top face plate.
  • Use the Plastic Opening Tools to pry off the tab located on the right side of the top face plate.
Ajouter un commentaire
Lift the plate off the laptop from right to left.
  • Lift the plate off the laptop from right to left.
  • Pull the plate out and remove it.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Remove the four 3mm Phillips #0 screws. Remove the four 3mm Phillips #0 screws.
  • Remove the four 3mm Phillips #0 screws.
Grasp the laptop with both hands as shown. Push the keyboard upwards with your thumbs to disconnect it.
  • Grasp the laptop with both hands as shown.
  • Push the keyboard upwards with your thumbs to disconnect it.
Lift the keyboard from the laptop and remove it. Ensure the connector is fully disconnected before lifting the keyboard out.
  • Lift the keyboard from the laptop and remove it.
  • Ensure the connector is fully disconnected before lifting the keyboard out.
Nathan Valm
Membre depuis le 20/03/2018
651 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team S3-G1, Peak Spring 2018 Membre de l'équipe UMass Dartmouth, Team S3-G1, Peak Spring 2018
UMASSD-PEAK-S18S3G1
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 13
