Aller au contenu principal
Dell Vostro 1710 Heatsink Replacement
Ce dont vous avez besoin
  1. Dell Vostro 1710 Heatsink Replacement, Battery: étape 1, image 1 de 2 Dell Vostro 1710 Heatsink Replacement, Battery: étape 1, image 2 de 2
    • Make certain that the power to your laptop is off.
    • Press and slide the two buttons outwards and away from the battery.
  2. Dell Vostro 1710 Heatsink Replacement: étape 2, image 1 de 1
    • Slide the battery away and parallel from the laptop.
  3. Dell Vostro 1710 Heatsink Replacement: étape 3, image 1 de 1
    • Remove the battery from the slot.
  4. Dell Vostro 1710 Heatsink Replacement, Back Panel: étape 4, image 1 de 2 Dell Vostro 1710 Heatsink Replacement, Back Panel: étape 4, image 2 de 2
    • Unscrew the eight 6mm screws with a Philips #1 screw driver.
  5. Dell Vostro 1710 Heatsink Replacement: étape 5, image 1 de 1
    • Lift back cover from the groove on the left side of the cover next to the symbol.
  6. Dell Vostro 1710 Heatsink Replacement, Fan: étape 6, image 1 de 2 Dell Vostro 1710 Heatsink Replacement, Fan: étape 6, image 2 de 2
    • Unclip the power supply by pulling the cable directly up and out of the socket.
  7. Dell Vostro 1710 Heatsink Replacement: étape 7, image 1 de 2 Dell Vostro 1710 Heatsink Replacement: étape 7, image 2 de 2
    • Remove the two 3mm screws located around the edge of the fan with a Philips #1 screw driver.
  8. Dell Vostro 1710 Heatsink Replacement: étape 8, image 1 de 2 Dell Vostro 1710 Heatsink Replacement: étape 8, image 2 de 2
    • Gently lift and pull to the left until the fan is free from the heatsink.
  9. Dell Vostro 1710 Heatsink Replacement, Heatsink: étape 9, image 1 de 2 Dell Vostro 1710 Heatsink Replacement, Heatsink: étape 9, image 2 de 2
    • Unscrew the four 8mm screws using a Phillips #1 screwdriver until the heatsink is free.
    • The screws do not come out, only loosen.
  10. Dell Vostro 1710 Heatsink Replacement: étape 10, image 1 de 2 Dell Vostro 1710 Heatsink Replacement: étape 10, image 2 de 2
    • Lift up on the heatsink to remove it from the laptop.
Tangxiao Sun
Membre depuis le 03/19/18
496 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S3-G7, Peak Spring 2018 Membre de l'équipe UMass Dartmouth, Team S3-G7, Peak Spring 2018
UMASSD-PEAK-S18S3G7
3 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 262
