Aller au contenu principal
Dell Vostro 1710 Keyboard Replacement
Ce dont vous avez besoin
  1. Dell Vostro 1710 Keyboard Replacement, Battery: étape 1, image 1 de 2 Dell Vostro 1710 Keyboard Replacement, Battery: étape 1, image 2 de 2
    • Make certain that the power to your laptop is off.
    • Press and slide the two buttons outwards and away from the battery.
  2. Dell Vostro 1710 Keyboard Replacement: étape 2, image 1 de 1
    • Slide the battery away and parallel from the laptop.
  3. Dell Vostro 1710 Keyboard Replacement: étape 3, image 1 de 1
    • Remove the battery from the slot.
  4. Dell Vostro 1710 Keyboard Replacement, Keyboard: étape 4, image 1 de 3 Dell Vostro 1710 Keyboard Replacement, Keyboard: étape 4, image 2 de 3 Dell Vostro 1710 Keyboard Replacement, Keyboard: étape 4, image 3 de 3
    • Use the plastic opening tool to loosen the plastic hinge cover that is located above the keyboard.
  5. Dell Vostro 1710 Keyboard Replacement: étape 5, image 1 de 2 Dell Vostro 1710 Keyboard Replacement: étape 5, image 2 de 2
    • Remove plastic hinge cover by gently lifting up the cover with a plastic opening tool from one side to the other.
  6. Dell Vostro 1710 Keyboard Replacement: étape 6, image 1 de 2 Dell Vostro 1710 Keyboard Replacement: étape 6, image 2 de 2
    • Remove the four 3mm Philips #1 head screws.
  7. Dell Vostro 1710 Keyboard Replacement: étape 7, image 1 de 2 Dell Vostro 1710 Keyboard Replacement: étape 7, image 2 de 2
    • Gently lift up the keyboard to remove.
    • Flip it over as it shown in the picture.
  8. Dell Vostro 1710 Keyboard Replacement: étape 8, image 1 de 2 Dell Vostro 1710 Keyboard Replacement: étape 8, image 2 de 2
    • Lift the black tab that the keyboard is plugged into.
  9. Dell Vostro 1710 Keyboard Replacement: étape 9, image 1 de 2 Dell Vostro 1710 Keyboard Replacement: étape 9, image 2 de 2
    • Pull directly outwards to remove the keyboard completely.
Tangxiao Sun
Membre depuis le 03/19/18
496 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S3-G7, Peak Spring 2018 Membre de l'équipe UMass Dartmouth, Team S3-G7, Peak Spring 2018
UMASSD-PEAK-S18S3G7
3 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 16
Total : 672
