Aller au contenu principal
Dell Vostro 3450 Hard Drive Replacement
Ce dont vous avez besoin
  1. Dell Vostro 3450 Hard Drive Replacement, Unlocking the Battery: étape 1, image 1 de 1
    • Slide the left and the right battery release latches to the unlock position.
  2. Dell Vostro 3450 Hard Drive Replacement, Removing the Battery: étape 2, image 1 de 1
    • Slide the battery and remove it from the computer.
  3. Dell Vostro 3450 Hard Drive Replacement, Press the ExpressCard: étape 3, image 1 de 1
    • Press the ExpressCard to release it from the computer.
  4. Dell Vostro 3450 Hard Drive Replacement, Slide the ExpressCard: étape 4, image 1 de 1
    • Slide the ExpressCard out of the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  5. Dell Vostro 3450 Hard Drive Replacement, Prying the Keyboard: étape 5, image 1 de 1
    • Press the keyboard down. Pry the keyboard with the use of a flat-head screwdriver towards the display to reveal the first keyboard retainer.
  6. Dell Vostro 3450 Hard Drive Replacement, Prying the Keyboard retainer: étape 6, image 1 de 1
    • Pry up the second keyboard retainer.
  7. Dell Vostro 3450 Hard Drive Replacement, Pry up the Keyboard Retainer: étape 7, image 1 de 1
    • Pry up the third keyboard retainer.
  8. Dell Vostro 3450 Hard Drive Replacement, Prying the Retainer: étape 8, image 1 de 1
    • Pry up the fourth keyboard retainer.
  9. Dell Vostro 3450 Hard Drive Replacement, Pull up the Keyboard: étape 9, image 1 de 1
    • Pull up the keyboard from the palm rest.
  10. Dell Vostro 3450 Hard Drive Replacement, Release the Latch: étape 10, image 1 de 1
    • Release the latch on the system board connector, then disconnect the keyboard cable.
  11. Dell Vostro 3450 Hard Drive Replacement, Loosen the Screw: étape 11, image 1 de 1
    • Loosen the screw that secures the memory door.
  12. Dell Vostro 3450 Hard Drive Replacement, Removing the Memory Door: étape 12, image 1 de 1
    • Pry up the memory door near the screw hole, lift and remove it.
  13. Dell Vostro 3450 Hard Drive Replacement, Remove the Screw: étape 13, image 1 de 1
    • Remove the screw that secures the optical drive to the computer.
  14. Dell Vostro 3450 Hard Drive Replacement, Prying the Drive: étape 14, image 1 de 1
    • Gently pry the optical drive out of the computer.
  15. Dell Vostro 3450 Hard Drive Replacement, Remove the Screws: étape 15, image 1 de 1
    • Remove the screws that secure the optical drive bracket.
  16. Dell Vostro 3450 Hard Drive Replacement, Removing the Optical Drive: étape 16, image 1 de 1
    • Remove the optical drive bracket from the optical drive module.
  17. Dell Vostro 3450 Hard Drive Replacement, Remove the Screws: étape 17, image 1 de 1
    • Remove the screws in the battery compartment.
  18. Dell Vostro 3450 Hard Drive Replacement, Remove the Screws: étape 18, image 1 de 1
    • Remove the screws in the optical drive compartment.
  19. Dell Vostro 3450 Hard Drive Replacement, Remove the Rubber: étape 19, image 1 de 1
    • Remove the rubber from the bottom base on the right side.
  20. Dell Vostro 3450 Hard Drive Replacement, Remove the Rubber: étape 20, image 1 de 1
    • Remove the rubber from the bottom base on the left side.
  21. Dell Vostro 3450 Hard Drive Replacement, Remove the Screws: étape 21, image 1 de 1
    • Remove all the screws from the bottom base.
  22. Dell Vostro 3450 Hard Drive Replacement, Remove the Screws: étape 22, image 1 de 1
    • Flip the computer around and remove the screws that secures the palm rest.
  23. Dell Vostro 3450 Hard Drive Replacement, Release the Latches: étape 23, image 1 de 1
    • Release the latches on the system board connector, then disconnect the touch pad cable and the finger printer cable.
  24. Dell Vostro 3450 Hard Drive Replacement, Release the Latch: étape 24, image 1 de 1
    • Release the latch on the system board connector and then disconnect the power button cable.
  25. Dell Vostro 3450 Hard Drive Replacement, Disconnecting the Key Cable: étape 25, image 1 de 1
    • Release the latch on the system board connector and then disconnect the hot key cable.
  26. Dell Vostro 3450 Hard Drive Replacement, Prying the Palm Rest: étape 26, image 1 de 1
    • Pry up the right side of the palm rest.
  27. Dell Vostro 3450 Hard Drive Replacement, Prying the Palm Rest: étape 27, image 1 de 1
    • Pry up the left side of the palm rest.
  28. Dell Vostro 3450 Hard Drive Replacement, Prying the Sides: étape 28, image 1 de 1
    • Pry up the sides of the palm rest and remove it from the computer.
  29. Dell Vostro 3450 Hard Drive Replacement, Remove the Screws: étape 29, image 1 de 1
    • Remove the screws that secure the hinge cover.
  30. Dell Vostro 3450 Hard Drive Replacement, Press Down on the Hooks: étape 30, image 1 de 1
    • Press down on the hooks highlighted in the image.
  31. Dell Vostro 3450 Hard Drive Replacement, Removing the Hinge Cover: étape 31, image 1 de 1
    • Flip the computer around and remove the hinge cover from the side.
  32. Dell Vostro 3450 Hard Drive Replacement, Remove the Screws: étape 32, image 1 de 1
    • Remove the screws that secure the display hinge.
  33. Dell Vostro 3450 Hard Drive Replacement, Loosen the Screw: étape 33, image 1 de 1
    • Loosen the screw that secures the low-voltage differential signaling (LVDS) cable.
  34. Dell Vostro 3450 Hard Drive Replacement, Disconnecting the LVDS Cable: étape 34, image 1 de 1
    • Disconnect the LVDS cable from the system board.
  35. Dell Vostro 3450 Hard Drive Replacement, Disconnecting the Wireless Cables: étape 35, image 1 de 1
    • Disconnect the wireless local area network (WLAN) antenna cable.
  36. Dell Vostro 3450 Hard Drive Replacement, Remove the Screws: étape 36, image 1 de 1
    • Remove the screws that secure the left hinge.
  37. Dell Vostro 3450 Hard Drive Replacement, Remove the Screws: étape 37, image 1 de 1
    • Remove the screws that secure the right hinge.
  38. Dell Vostro 3450 Hard Drive Replacement, Lifting the Display Assembly: étape 38, image 1 de 1
    • Lift the display assembly and remove it from the computer.
  39. Dell Vostro 3450 Hard Drive Replacement, Remove the Screw: étape 39, image 1 de 1
    • Remove the screw that secures the WLAN card.
  40. Dell Vostro 3450 Hard Drive Replacement, Pull the Card: étape 40, image 1 de 1
    • Pull the WLAN card straight out of its socket and remove it.
  41. Dell Vostro 3450 Hard Drive Replacement, Release the Latch: étape 41, image 1 de 1
    • Release the latch on the system board and then disconnect the VGA cable.
  42. Dell Vostro 3450 Hard Drive Replacement, Remove the Screw: étape 42, image 1 de 1
    • Remove the screw that secures the VGA board.
  43. Dell Vostro 3450 Hard Drive Replacement, Remove the VGA Board: étape 43, image 1 de 1
    • Remove the VGA board from the chassis.
  44. Dell Vostro 3450 Hard Drive Replacement, Disconnect the System Fan Cable: étape 44, image 1 de 1
    • Disconnect the system fan cable from the system board.
  45. Dell Vostro 3450 Hard Drive Replacement, Remove the Screw: étape 45, image 1 de 1
    • Remove the screw that secures the system fan.
  46. Dell Vostro 3450 Hard Drive Replacement, Remove the System Fan: étape 46, image 1 de 1
    • Remove the system fan from the bottom base module.
  47. Dell Vostro 3450 Hard Drive Replacement, Disconnect the DC-in Cable: étape 47, image 1 de 1
    • Disconnect the DC-in cable connector from the system board.
  48. Dell Vostro 3450 Hard Drive Replacement, Disconnecting the Speaker Cable: étape 48, image 1 de 1
    • Disconnect the speaker cable from the system board.
  49. Dell Vostro 3450 Hard Drive Replacement, Remove the Screws: étape 49, image 1 de 1
    • Remove the screws that secures the system board.
  50. Dell Vostro 3450 Hard Drive Replacement, Disconnecting the System Board: étape 50, image 1 de 1
    • Disconnect the system board from the Input/Output panel.
  51. Dell Vostro 3450 Hard Drive Replacement, Remove the System Board: étape 51, image 1 de 1
    • Lift and remove system board from the chassis.
  52. Dell Vostro 3450 Hard Drive Replacement, Hard Drive: étape 52, image 1 de 1
    • Remove the screws that secures the hard drive bracket
  53. Dell Vostro 3450 Hard Drive Replacement: étape 53, image 1 de 1
    • Slide the hard-drive module to release it from the system board
  54. Dell Vostro 3450 Hard Drive Replacement: étape 54, image 1 de 1
    • Remove the hard drive module from the system board.
  55. Dell Vostro 3450 Hard Drive Replacement: étape 55, image 1 de 1
    • Remove the screws that secures the hard-drive bracket on one side.
  56. Dell Vostro 3450 Hard Drive Replacement: étape 56, image 1 de 1
    • Remove the screws that secures the hard-drive bracket on the other side
  57. Dell Vostro 3450 Hard Drive Replacement: étape 57, image 1 de 1
    • Slide the hard drive from the hard-drive bracket.
4 autres ont terminé cette réparation.
Johnathan Hammond
Membre depuis le 02/28/18
44 830 Réputation
408 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 985 tutoriels rédigés
4 commentaires
Stupidest HDD location EVER! You have to fully disassemble your device for the simple operation.
vytookas - Réponse
Who the !&&* designs a hard drive location that requires complete disassembly of the motherboard and the laptop to replace. Horrible, horrible design.
garbage911garbage - Réponse
It’s possible to skip removing the display and the WLAN card, which saves a bit of time and trouble. I think I understand why this guide and Dell’s user guide recommend removing these parts, it makes other steps a _little_ easier, but I didn’t find it was worthwhile.
BorpoIT - Réponse
I’ve done this upgrade twice now, and I think the iFixit Opening Tool (along with the spudger) makes this job easier. Besides releasing latches for the palm rest and the memory door, it was very helpful to pry up the System Board from the Input/Output Panel.
BorpoIT - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 25
Total : 4,779
