Aller au contenu principal
Dell Vostro 3450 Optical Drive Replacement
Ce dont vous avez besoin
  1. Dell Vostro 3450 Optical Drive Replacement, Unlocking the Battery: étape 1, image 1 de 1
    • Slide the left and the right battery release latches to the unlock position.
  2. Dell Vostro 3450 Optical Drive Replacement, Removing the Battery: étape 2, image 1 de 1
    • Slide the battery and remove it from the computer.
  3. Dell Vostro 3450 Optical Drive Replacement, Loosen the Screw: étape 3, image 1 de 1
    • Loosen the screw that secures the memory door.
  4. Dell Vostro 3450 Optical Drive Replacement, Removing the Memory Door: étape 4, image 1 de 1
    • Pry up the memory door near the screw hole, lift and remove it.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  5. Dell Vostro 3450 Optical Drive Replacement, Remove the Screw: étape 5, image 1 de 1
    • Remove the screw that secures the optical drive to the computer.
  6. Dell Vostro 3450 Optical Drive Replacement, Prying the Drive: étape 6, image 1 de 1
    • Gently pry the optical drive out of the computer.
  7. Dell Vostro 3450 Optical Drive Replacement, Remove the Screws: étape 7, image 1 de 1
    • Remove the screws that secure the optical drive bracket.
  8. Dell Vostro 3450 Optical Drive Replacement, Removing the Optical Drive: étape 8, image 1 de 1
    • Remove the optical drive bracket from the optical drive module.
Ligne d'arrivée
2 autres ont terminé cette réparation.
Johnathan Hammond
Membre depuis le 02/28/18
44 953 Réputation
408 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 986 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 11
30 derniers jours : 18
Total : 179
