Aller au contenu principal
Dell Vostro 3450 System Board Replacement
Ce dont vous avez besoin
  1. Dell Vostro 3450 System Board Replacement, Unlocking the Battery: étape 1, image 1 de 1
    • Slide the left and the right battery release latches to the unlock position.
  2. Dell Vostro 3450 System Board Replacement, Removing the Battery: étape 2, image 1 de 1
    • Slide the battery and remove it from the computer.
  3. Dell Vostro 3450 System Board Replacement, Press the ExpressCard: étape 3, image 1 de 1
    • Press the ExpressCard to release it from the computer.
  4. Dell Vostro 3450 System Board Replacement, Slide the ExpressCard: étape 4, image 1 de 1
    • Slide the ExpressCard out of the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  5. Dell Vostro 3450 System Board Replacement, Prying the Keyboard: étape 5, image 1 de 1
    • Press the keyboard down. Pry the keyboard with the use of a flat-head screwdriver towards the display to reveal the first keyboard retainer.
  6. Dell Vostro 3450 System Board Replacement, Prying the Keyboard retainer: étape 6, image 1 de 1
    • Pry up the second keyboard retainer.
  7. Dell Vostro 3450 System Board Replacement, Pry up the Keyboard Retainer: étape 7, image 1 de 1
    • Pry up the third keyboard retainer.
  8. Dell Vostro 3450 System Board Replacement, Prying the Retainer: étape 8, image 1 de 1
    • Pry up the fourth keyboard retainer.
  9. Dell Vostro 3450 System Board Replacement, Pull up the Keyboard: étape 9, image 1 de 1
    • Pull up the keyboard from the palm rest.
  10. Dell Vostro 3450 System Board Replacement, Release the Latch: étape 10, image 1 de 1
    • Release the latch on the system board connector, then disconnect the keyboard cable.
  11. Dell Vostro 3450 System Board Replacement, Loosen the Screw: étape 11, image 1 de 1
    • Loosen the screw that secures the memory door.
  12. Dell Vostro 3450 System Board Replacement, Removing the Memory Door: étape 12, image 1 de 1
    • Pry up the memory door near the screw hole, lift and remove it.
  13. Dell Vostro 3450 System Board Replacement, Remove the Screw: étape 13, image 1 de 1
    • Remove the screw that secures the optical drive to the computer.
  14. Dell Vostro 3450 System Board Replacement, Prying the Drive: étape 14, image 1 de 1
    • Gently pry the optical drive out of the computer.
  15. Dell Vostro 3450 System Board Replacement, Remove the Screws: étape 15, image 1 de 1
    • Remove the screws that secure the optical drive bracket.
  16. Dell Vostro 3450 System Board Replacement, Removing the Optical Drive: étape 16, image 1 de 1
    • Remove the optical drive bracket from the optical drive module.
  17. Dell Vostro 3450 System Board Replacement, Remove the Screws: étape 17, image 1 de 1
    • Remove the screws in the battery compartment.
  18. Dell Vostro 3450 System Board Replacement, Remove the Screws: étape 18, image 1 de 1
    • Remove the screws in the optical drive compartment.
  19. Dell Vostro 3450 System Board Replacement, Remove the Rubber: étape 19, image 1 de 1
    • Remove the rubber from the bottom base on the right side.
  20. Dell Vostro 3450 System Board Replacement, Remove the Rubber: étape 20, image 1 de 1
    • Remove the rubber from the bottom base on the left side.
  21. Dell Vostro 3450 System Board Replacement, Remove the Screws: étape 21, image 1 de 1
    • Remove all the screws from the bottom base.
  22. Dell Vostro 3450 System Board Replacement, Remove the Screws: étape 22, image 1 de 1
    • Flip the computer around and remove the screws that secures the palm rest.
  23. Dell Vostro 3450 System Board Replacement, Release the Latches: étape 23, image 1 de 1
    • Release the latches on the system board connector, then disconnect the touch pad cable and the finger printer cable.
  24. Dell Vostro 3450 System Board Replacement, Release the Latch: étape 24, image 1 de 1
    • Release the latch on the system board connector and then disconnect the power button cable.
  25. Dell Vostro 3450 System Board Replacement, Disconnecting the Key Cable: étape 25, image 1 de 1
    • Release the latch on the system board connector and then disconnect the hot key cable.
  26. Dell Vostro 3450 System Board Replacement, Prying the Palm Rest: étape 26, image 1 de 1
    • Pry up the right side of the palm rest.
  27. Dell Vostro 3450 System Board Replacement, Prying the Palm Rest: étape 27, image 1 de 1
    • Pry up the left side of the palm rest.
  28. Dell Vostro 3450 System Board Replacement, Prying the Sides: étape 28, image 1 de 1
    • Pry up the sides of the palm rest and remove it from the computer.
  29. Dell Vostro 3450 System Board Replacement, Remove the Screws: étape 29, image 1 de 1
    • Remove the screws that secure the hinge cover.
  30. Dell Vostro 3450 System Board Replacement, Press Down on the Hooks: étape 30, image 1 de 1
    • Press down on the hooks highlighted in the image.
  31. Dell Vostro 3450 System Board Replacement, Removing the Hinge Cover: étape 31, image 1 de 1
    • Flip the computer around and remove the hinge cover from the side.
  32. Dell Vostro 3450 System Board Replacement, Remove the Screws: étape 32, image 1 de 1
    • Remove the screws that secure the display hinge.
  33. Dell Vostro 3450 System Board Replacement, Loosen the Screw: étape 33, image 1 de 1
    • Loosen the screw that secures the low-voltage differential signaling (LVDS) cable.
  34. Dell Vostro 3450 System Board Replacement, Disconnecting the LVDS Cable: étape 34, image 1 de 1
    • Disconnect the LVDS cable from the system board.
  35. Dell Vostro 3450 System Board Replacement, Disconnecting the Wireless Cables: étape 35, image 1 de 1
    • Disconnect the wireless local area network (WLAN) antenna cable.
  36. Dell Vostro 3450 System Board Replacement, Remove the Screws: étape 36, image 1 de 1
    • Remove the screws that secure the left hinge.
  37. Dell Vostro 3450 System Board Replacement, Remove the Screws: étape 37, image 1 de 1
    • Remove the screws that secure the right hinge.
  38. Dell Vostro 3450 System Board Replacement, Lifting the Display Assembly: étape 38, image 1 de 1
    • Lift the display assembly and remove it from the computer.
  39. Dell Vostro 3450 System Board Replacement, Remove the Screw: étape 39, image 1 de 1
    • Remove the screw that secures the WLAN card.
  40. Dell Vostro 3450 System Board Replacement, Pull the Card: étape 40, image 1 de 1
    • Pull the WLAN card straight out of its socket and remove it.
  41. Dell Vostro 3450 System Board Replacement, Release the Latch: étape 41, image 1 de 1
    • Release the latch on the system board and then disconnect the VGA cable.
  42. Dell Vostro 3450 System Board Replacement, Remove the Screw: étape 42, image 1 de 1
    • Remove the screw that secures the VGA board.
  43. Dell Vostro 3450 System Board Replacement, Remove the VGA Board: étape 43, image 1 de 1
    • Remove the VGA board from the chassis.
  44. Dell Vostro 3450 System Board Replacement, Disconnect the System Fan Cable: étape 44, image 1 de 1
    • Disconnect the system fan cable from the system board.
  45. Dell Vostro 3450 System Board Replacement, Remove the Screw: étape 45, image 1 de 1
    • Remove the screw that secures the system fan.
  46. Dell Vostro 3450 System Board Replacement, Remove the System Fan: étape 46, image 1 de 1
    • Remove the system fan from the bottom base module.
  47. Dell Vostro 3450 System Board Replacement, Disconnect the DC-in Cable: étape 47, image 1 de 1
    • Disconnect the DC-in cable connector from the system board.
  48. Dell Vostro 3450 System Board Replacement, Disconnecting the Speaker Cable: étape 48, image 1 de 1
    • Disconnect the speaker cable from the system board.
  49. Dell Vostro 3450 System Board Replacement, Remove the Screws: étape 49, image 1 de 1
    • Remove the screws that secures the system board.
  50. Dell Vostro 3450 System Board Replacement, Disconnecting the System Board: étape 50, image 1 de 1
    • Disconnect the system board from the Input/Output panel.
  51. Dell Vostro 3450 System Board Replacement, Remove the System Board: étape 51, image 1 de 1
    • Lift and remove system board from the chassis.
Ligne d'arrivée
Johnathan Hammond
Membre depuis le 02/28/18
44 953 Réputation
408 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 986 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 15
Total : 424
