Pièces
Aucune pièce nécessaire.
Slide the release latches to unlock the battery.
  • Slide the release latches to unlock the battery.
Ajouter un commentaire
Slide the battery out of the chassis and remove it from the computer.
  • Slide the battery out of the chassis and remove it from the computer.
  • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Loosen the screws that secure the memory door.
  • Loosen the screws that secure the memory door.
Pry up the memory door near the screw hole, lift, and remove it
  • Pry up the memory door near the screw hole, lift, and remove it
Pry the retention clips away from the memory module until it pops up.
  • Pry the retention clips away from the memory module until it pops up.
Remove the memory module from its connector on the system board.
  • Remove the memory module from its connector on the system board.
Johnathan Hammond
Membre depuis le 28/02/2018
33 511 Réputation
412 tutoriels rédigés
Équipe
Informative Technologies Inc. Membre de l'équipe Informative Technologies Inc.
Community
15 membres
857 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 15
