Aller au contenu principal
Dell Vostro 500 Memory Module Replacement
Ce dont vous avez besoin
  1. Dell Vostro 500 Memory Module Replacement, Removing the Battery: étape 1, image 1 de 1
    • Slide the battery release latch toward the side of the computer until it is engaged.
    • Slide the battery out of the bay.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  2. Dell Vostro 500 Memory Module Replacement, Removing the Cover: étape 2, image 1 de 1
    • Turn the computer upside-down, loosen the eight captive screws on the cover and remove the cover.
  3. Dell Vostro 500 Memory Module Replacement, Popping up the Memory Module: étape 3, image 1 de 1
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • NOTICE: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer).
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
    • Remove the module from the connector.
Ligne d'arrivée
Johnathan Hammond
Membre depuis le 02/28/18
44 953 Réputation
408 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 986 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 9
Total : 83
