Aller au contenu principal
Dell XPS 12 9250 Solid-State Drive Replacement
Ce dont vous avez besoin
  1. Dell XPS 12 9250 Solid-State Drive Replacement, Removing the Back Cover: étape 1, image 1 de 2 Dell XPS 12 9250 Solid-State Drive Replacement, Removing the Back Cover: étape 1, image 2 de 2
    • Turn the tablet over.
    • Remove the screws that secure the back-cover assembly to the display assembly.
    • Using a plastic scribe, pry up along the edges of the back-cover assembly.
    • Carefully, lift the back-cover assembly and turn it over.
  2. Dell XPS 12 9250 Solid-State Drive Replacement, Removing the Battery: étape 2, image 1 de 1
    • Remove the screws that secure the battery to the back-cover assembly.
    • Disconnect the battery cable from the system board.
    • Lift the battery, along with its cable, off the back-cover assembly.
  3. Dell XPS 12 9250 Solid-State Drive Replacement, Removing M.2 SSD: étape 3, image 1 de 1
    • Remove the screw that secures the solid-state drive to the back-cover assembly.
    • Lift and slide the solid-state drive off the back-cover assembly.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
Ligne d'arrivée
Johnathan Hammond
Membre depuis le 02/28/18
44 820 Réputation
408 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 14
Total : 1,466
