Aller au contenu principal
Dell XPS 13 9370 Battery Replacement
Ce dont vous avez besoin
    • Save and close all open files and exit all open applications.
    • Shut down your computer. Click Start > Power > Shut down.
    • Disconnect your computer and all attached devices from their electrical outlets.
    • Disconnect all attached network devices and peripherals, such as keyboard, mouse, and monitor from your computer.
    • Remove any media card and optical disc from your computer, if applicable.
  1. Dell XPS 13 9370 Battery Replacement, Remove the base cover screws: étape 2, image 1 de 1
    • Remove the eight screws (M2x3, Torx) that secure the base cover to the palm-rest assembly.
  2. Dell XPS 13 9370 Battery Replacement, Remove the base cover: étape 3, image 1 de 2 Dell XPS 13 9370 Battery Replacement, Remove the base cover: étape 3, image 2 de 2
    • With the computer face-down, open the computer at an angle.
    • Using a plastic scribe (spudger), pry the base cover from the palm-rest assembly.
    • Moving the base cover from left to right, release the clips securing the base cover to the palm-rest assembly.
    • Lift the base cover from the palm-rest assembly.
  3. Dell XPS 13 9370 Battery Replacement, Disconnect battery cable: étape 4, image 1 de 1
    • Disconnect the battery cable from the system board.
  4. Dell XPS 13 9370 Battery Replacement, Remove the battery: étape 5, image 1 de 1
    • Remove the four screws (M2x2) that secure the battery to the palm-rest assembly.
    • Remove the screw (M1.6x4) that secures the battery to the palm-rest assembly.
    • Lift the battery off the palm-rest assembly.
    • Turn the computer over, open the display, and press the power button for about 5 seconds to ground the computer.
To replace the battery & reassemble your device, follow these instructions in reverse order.
23 autres ont terminé cette réparation.
Max Kletskov
Membre depuis le 04/22/20
40 298 Réputation
16 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
17 199 tutoriels rédigés
8 commentaires
Is the battery an original dell battery?
mnyousafva - Réponse
Why doesn’t it say what tools are needed?
Noah Guirguis - Réponse
Excellent guide. Took me about 25 minutes. Works perfectly.
Jeff Doremus - Réponse
Instructions were perfect, thanks for the great guide!
surfdaworld - Réponse
Boom, in a good way! I fixed it!
Chris Cox - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 24
7 derniers jours : 101
30 derniers jours : 501
Total : 15,301
