Introduction
How to remove the battery of a Dell XPS 13 L322X laptop. The images and information in this guide were taken from this computer's service manual, which can be found on the product page.
Pièces
Aucune pièce nécessaire.
After turning off the computer, use a Torx 5 screwdriver to remove the 10 screws (#2) from the computer's base.
  • After turning off the computer, use a Torx 5 screwdriver to remove the 10 screws (#2) from the computer's base.
  • Using a prying tool or a fingernail, lift up the base cover (#1).
Ajouter un commentaire
Lift up the small latch which holds down the power-light board cable (#3) down. Remove the cable by pulling out sideways.
  • Lift up the small latch which holds down the power-light board cable (#3) down. Remove the cable by pulling out sideways.
  • After removing the Philips screw which holds down the power-light board (#1), remove the power light board (#2) and its cable.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Disconnect the battery cable from the system-board.
  • Disconnect the battery cable from the system-board.
    • Remove the screws that secure the battery to the palm-rest assembly.
      • Lift the battery off the palm-rest assembly.
Align the screw holes on the New battery with the screw holes on the palm-rest assembly.
  • Align the screw holes on the New battery with the screw holes on the palm-rest assembly.
    • Replace the screws that secure the battery to the palm-rest assembly.
      • Connect the battery cable to the system-board.
To reassemble your device, reattatch the power board cable and screw back on the base cover.
2 autre(s) ont terminé cette réparation.
Johnathan Hammond
Membre depuis le 28/02/2018
33 511 Réputation
412 tutoriels rédigés
Équipe
Informative Technologies Inc. Membre de l'équipe Informative Technologies Inc.
Community
15 membres
845 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 16
Total : 57
