Aller au contenu principal
Dell XPS 15 9510 Rear Panel Replacement
Ce dont vous avez besoin
  1. Dell XPS 15 9510 Rear Panel Replacement, Rear Panel: étape 1, image 1 de 1
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
  2. Dell XPS 15 9510 Rear Panel Replacement: étape 2, image 1 de 1
    • The metal case of the XPS 15 9510 is extremely sharp, so be careful not to run your fingers along the edge when disassembling the laptop.
    • Wedge the case apart with a nylon spudger.
    • If the plastic one isn't possible to insert, use the metal spudger to carefully create a small gap first.
    • Slide spudger along each side of the laptop
  3. Dell XPS 15 9510 Rear Panel Replacement: étape 3, image 1 de 1
    • Lift the back panel of the laptop off and set it aside.
Joseph Remondi
Membre depuis le 03/30/22
278 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-3, Mellen Spring 2022 Membre de l'équipe UMass Dartmouth, Team 1-3, Mellen Spring 2022
UMASSD-MELLEN-S22S1G3
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 27
Total : 1,104
