Aller au contenu principal
Dell XPS 9720 Battery Replacement
Ce dont vous avez besoin
  1. Dell XPS 9720 Battery Replacement, Remove back cover: étape 1, image 1 de 1
    • Remove 8 T5 screws. Use an opening tool to pop open the plastic tabs that hold the aluminum and plastic halves of the shell together. Begin by inserting the tool at any point, then sliding it around the perimeter of the device to release all of the tabs. There are no tabs along the hinge side of the device.
  2. Dell XPS 9720 Battery Replacement, Unplug the battery: étape 2, image 1 de 2 Dell XPS 9720 Battery Replacement, Unplug the battery: étape 2, image 2 de 2
    • Place a finger through the plastic loop attached to the battery plug, and pull firmly away from the motherboard.
  3. Dell XPS 9720 Battery Replacement, Remove battery screws: étape 3, image 1 de 2 Dell XPS 9720 Battery Replacement, Remove battery screws: étape 3, image 2 de 2
    • Unscrew the 7 PH1 screws retaining the battery.
    • The battery can now be lifted from the chassis.
    • Reverse the steps to install the new battery.
Sebastien Bolle
Membre depuis le 09/12/15
326 Réputation
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 9
30 derniers jours : 52
Total : 788
