Introduction
Before you begin the RAM replacement process, be sure to ground yourself. Grounding yourself prevents short circuiting the device, and/or shocking yourself. An easy way to do so would be to remove one of your shoes.
Pièces
Aucune pièce nécessaire.
Push the sliding button near the battery compartment.
  • Push the sliding button near the battery compartment.
Ajouter un commentaire
Slide the button next to the battery and lift up on the lip of the battery edge.
  • Slide the button next to the battery and lift up on the lip of the battery edge.
Lift and remove the battery. Lift and remove the battery.
  • Lift and remove the battery.
Remove the two M2x3mm screws from the center panel on the back of computer with a Phillips #0 screwdriver head.
  • Remove the two M2x3mm screws from the center panel on the back of computer with a Phillips #0 screwdriver head.
Use a plastic opening tool to pull up and remove the center panel. Use a plastic opening tool to pull up and remove the center panel. Use a plastic opening tool to pull up and remove the center panel.
  • Use a plastic opening tool to pull up and remove the center panel.
Pull the two clips on either side of the memory sticks.
  • Pull the two clips on either side of the memory sticks.
Slide the memory sticks out of their clips. Slide the memory sticks out of their clips. Slide the memory sticks out of their clips.
  • Slide the memory sticks out of their clips.
Ashley Hoffman
Membre depuis le 13/02/2018
255 Réputation
2 tutoriels rédigés
Équipe
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 12
Total : 51
