Introduction
This is the beginning process to remove or replace any functional component in the AirPort.
Pièces
Aucune pièce nécessaire.
Remove the three 5mm T7 Torx screws from the back panel.
  • Remove the three 5mm T7 Torx screws from the back panel.
Ajouter un commentaire
Remove one 5mm phillips screw located under the identification sticker.  You will need to remove the sticker or make a hole to get to the screw.
  • Remove one 5mm phillips screw located under the identification sticker. You will need to remove the sticker or make a hole to get to the screw.
Separate the bottom and top casings.
  • Separate the bottom and top casings.
Remove the metal case from the top case of the AirPort, there are no screws holding it on. Remove the four screws from the metal casing.
  • Remove the metal case from the top case of the AirPort, there are no screws holding it on.
  • Remove the four screws from the metal casing.
2 autre(s) ont terminé cette réparation.
Michael Garcia
Membre depuis le 12/10/2011
369 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 17-15, Regan Fall 2011 Membre de l'équipe Cal Poly, Team 17-15, Regan Fall 2011
CPSU-REGAN-F11S17G15
3 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 6
Total : 1,633
