Aller au contenu principal
Disassembling Canon PowerShot SD1100 IS Front and Rear Cover
Ce dont vous avez besoin
  1. Disassembling Canon PowerShot SD1100 IS Front and Rear Cover, Front and Rear Cover: étape 1, image 1 de 2 Disassembling Canon PowerShot SD1100 IS Front and Rear Cover, Front and Rear Cover: étape 1, image 2 de 2
    • Remove wrist strap and battery.
  2. Disassembling Canon PowerShot SD1100 IS Front and Rear Cover: étape 2, image 1 de 3 Disassembling Canon PowerShot SD1100 IS Front and Rear Cover: étape 2, image 2 de 3 Disassembling Canon PowerShot SD1100 IS Front and Rear Cover: étape 2, image 3 de 3
    • Remove 2 screws from each side of the camera (4 total, 0.102 in).
    • Remove 2 screws from the bottom on the camera (0.138 in).
    • Do not mix the 4 side screws with the 2 bottoms ones; they are different sizes.
  3. Disassembling Canon PowerShot SD1100 IS Front and Rear Cover: étape 3, image 1 de 3 Disassembling Canon PowerShot SD1100 IS Front and Rear Cover: étape 3, image 2 de 3 Disassembling Canon PowerShot SD1100 IS Front and Rear Cover: étape 3, image 3 de 3
    • Gently pull off the front cover.
    • The plate on the side should come off.
    • Gently pull off the back cover.
  4. Disassembling Canon PowerShot SD1100 IS Front and Rear Cover: étape 4, image 1 de 1
    • The cases should now be removed.
3 autres ont terminé cette réparation.
Tyler Grossheim
Membre depuis le 01/25/11
1 470 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 3-32, Regan Winter 2011 Membre de l'équipe Cal Poly, Team 3-32, Regan Winter 2011
CPSU-REGAN-W11S3G32
3 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 6
Total : 3,397
