Introduction
Removing the back cover allows access to the LCD display and the flash assembly.
Pièces
Aucune pièce nécessaire.
Remove one 2.25mm screw on the bottom.
  • Remove one 2.25mm screw on the bottom.
Ajouter un commentaire
Remove two 2.25mm screws on the right side looking from the front.
  • Remove two 2.25mm screws on the right side looking from the front.
Remove one 4.7mm screw on the side with the AV output.
  • Remove one 4.7mm screw on the side with the AV output.
Pull off the back cover.
  • Pull off the back cover.
  • The back cover tends to stick in the top corner (near the mode dial) due to a metal clip. Jiggle the cover side to side as you pull it out.
Jeremy Rabaino
Membre depuis le 10/10/2010
135 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 20-9, Maness Fall 2010 Membre de l'équipe Cal Poly, Team 20-9, Maness Fall 2010
CPSU-MANESS-F10S20G9
5 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 2,422
