Aller au contenu principal
Canon Powershot SD880 LCD Display Replacement
Ce dont vous avez besoin
  1. Canon Powershot SD880 LCD Display Replacement, Back Cover: étape 1, image 1 de 3 Canon Powershot SD880 LCD Display Replacement, Back Cover: étape 1, image 2 de 3 Canon Powershot SD880 LCD Display Replacement, Back Cover: étape 1, image 3 de 3
    • Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
    • Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
    • One screw will be located under the rubber USB flap.
    • Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    • Slowly pull the back cover off of the camera.
  2. Canon Powershot SD880 LCD Display Replacement, LCD Display: étape 2, image 1 de 3 Canon Powershot SD880 LCD Display Replacement, LCD Display: étape 2, image 2 de 3 Canon Powershot SD880 LCD Display Replacement, LCD Display: étape 2, image 3 de 3
    • Remove the two 2.9 mm screws at the top-right corner and bottom-left corner of the LCD screen using a Phillips #0 screwdriver.
    • Disconnect the ribbons that connect the screen to the camera.
    • Lift the screen off.
Ben Tupas
Membre depuis le 01/13/11
317 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 13-3, Forte Winter 2011 Membre de l'équipe Cal Poly, Team 13-3, Forte Winter 2011
CPSU-FORTE-W11S13G3
5 membres
8 tutoriels rédigés
Un commentaire
Hm. "Disconnect the ribbons" resulted in a torn ribbon, and so a dead camera, I think. This also doesn't say how to take the LCD screen out of its frame. Alas.
Maelduin - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 2,306
