Aller au contenu principal
Disassembling Canon Powershot SD880 Logic Board
Ce dont vous avez besoin
  1. Disassembling Canon Powershot SD880 Logic Board, Back Cover: étape 1, image 1 de 3 Disassembling Canon Powershot SD880 Logic Board, Back Cover: étape 1, image 2 de 3 Disassembling Canon Powershot SD880 Logic Board, Back Cover: étape 1, image 3 de 3
    • Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
    • Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
    • One screw will be located under the rubber USB flap.
    • Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    • Slowly pull the back cover off of the camera.
  2. Disassembling Canon Powershot SD880 Logic Board, Front Cover: étape 2, image 1 de 3 Disassembling Canon Powershot SD880 Logic Board, Front Cover: étape 2, image 2 de 3 Disassembling Canon Powershot SD880 Logic Board, Front Cover: étape 2, image 3 de 3
    • Remove the 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    • Remove the 4.1 mm screw from the menu button side of the camera using a Phillips #00 screwdriver.
    • The two screws on the other side of the camera were already removed when the back cover was taken off.
  3. Disassembling Canon Powershot SD880 Logic Board, Top Panel: étape 3, image 1 de 2 Disassembling Canon Powershot SD880 Logic Board, Top Panel: étape 3, image 2 de 2
    • Unplug the green and white plugs that connect the top panel to the top of the logic board.
    • Dislodge the tab above the lens.
    • Dislodge the tab at the back.
  4. Disassembling Canon Powershot SD880 Logic Board, Logic Board: étape 4, image 1 de 1
    • Remove 2 screws(1.75mm) using a screwdriver.
    • Detach 3 ribbons by pulling up on them. All are on the front of the camera.
  5. Disassembling Canon Powershot SD880 Logic Board: étape 5, image 1 de 2 Disassembling Canon Powershot SD880 Logic Board: étape 5, image 2 de 2
    • Remove the newly exposed screw(1.75mm) with screwdriver.
    • Unhinge the black tab to slide out the ribbon.
    • The only thing keeping logic board in place is a black nub. Lift the logic board from that corner with increasing force until it pops out.
Juan Miguel
Membre depuis le 01/13/11
101 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 13-3, Forte Winter 2011 Membre de l'équipe Cal Poly, Team 13-3, Forte Winter 2011
CPSU-FORTE-W11S13G3
5 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 3
Total : 1,984
