Introduction
This little bugger can be removed if it's causing you trouble.
Pièces
Aucune pièce nécessaire.
Find the battery and the battery tabs located on the bottom of the Compaq Mini. Find the battery and the battery tabs located on the bottom of the Compaq Mini.
  • Find the battery and the battery tabs located on the bottom of the Compaq Mini.
Ajouter un commentaire
Push the tabs inward and slide the battery out. Push the tabs inward and slide the battery out. Push the tabs inward and slide the battery out.
  • Push the tabs inward and slide the battery out.
Find and remove the two screws on the bottom of your Compaq Mini covering the memory compartment. Note that the screws are attached to the panel.
  • Find and remove the two screws on the bottom of your Compaq Mini covering the memory compartment.
    • Note that the screws are attached to the panel.
Push out side tabs.
  • Push out side tabs.
Remove the rubber pads located on the corners of your Compaq Mini. There may be junk underneath it. This is residue left from the glue that held on the rubber pad. Just scrape it away to find the screw.
  • Remove the rubber pads located on the corners of your Compaq Mini.
  • There may be junk underneath it. This is residue left from the glue that held on the rubber pad. Just scrape it away to find the screw.
Unscrew all the corner screws. There are four total, one under each rubber pad. Unscrew all the corner screws. There are four total, one under each rubber pad.
  • Unscrew all the corner screws. There are four total, one under each rubber pad.
Unscrew the screw for the bottom case located in the RAM compartment. Unscrew the screw for the bottom case located in the RAM compartment.
  • Unscrew the screw for the bottom case located in the RAM compartment.
Falta um passo, pois nos modelos COMPAQ MINI 110, existe um parafuso que segura o teclado, que se encontra bem escondido dentro da cavidade que encaixa a bateria.
Amilcar Correia - Réponse
Remove the three screws in the silver tabs at the back of the keyboard. The red circles show where they are located at the back of the base under the screen. Remove the three screws in the silver tabs at the back of the keyboard. The red circles show where they are located at the back of the base under the screen.
  • Remove the three screws in the silver tabs at the back of the keyboard. The red circles show where they are located at the back of the base under the screen.
3 screws in red circles are actually on metal tabs in the battery compartment, 1 deeper than the other 2. There is a keyboard symbol for each of the 3 screws.
Step 8B: Lift out keyboard by pushing upwards on the 2 accessible metal tabs. This is the most difficult step. Lack of Quality Control during assembly may prevent the kevboard from lifting out without breaking!!
John - Réponse
This step may be performed after battery removal. Use care when removing ribbon cable: the white clips holding the black plastic "keeper" are fragile. Reassembly possible without white clips; however, jostling may cause the ribbon to come free.
Jason L - Réponse
Remove the three screws.
  • Remove the three screws.
Pull up on the tab. Pull up on the tab.
  • Pull up on the tab.
Remove the eight screws from the plastic top cover.
  • Remove the eight screws from the plastic top cover.
Pry up the top plastic cover using a spudger. Under the screen there are two tabs that need to be pushed in. Under the screen there are two tabs that need to be pushed in.
  • Pry up the top plastic cover using a spudger.
    • Under the screen there are two tabs that need to be pushed in.
Careful lifting up the cover because the track pad is still attached. Remove the cable by pulling it up.
  • Careful lifting up the cover because the track pad is still attached.
  • Remove the cable by pulling it up.
Take out the four screws that keep the bottom of the hinges attached to the base. Take out the four screws that keep the bottom of the hinges attached to the base. Take out the four screws that keep the bottom of the hinges attached to the base.
  • Take out the four screws that keep the bottom of the hinges attached to the base.
Pry off the top plastic cover of the display assembly. Note: There is adhesive tape holding the cover on. Note: The spudger may go all the way through to the screen-side of the cover. This is ok and will not damage anything.
  • Pry off the top plastic cover of the display assembly.
  • Note: There is adhesive tape holding the cover on.
  • Note: The spudger may go all the way through to the screen-side of the cover. This is ok and will not damage anything.
Remove the 4 screws keeping the screen on the plastic assembly. Remove the 4 screws keeping the screen on the plastic assembly. Remove the 4 screws keeping the screen on the plastic assembly.
  • Remove the 4 screws keeping the screen on the plastic assembly.
Take the screen off the metal connectors by unscrewing each side. Each side has 2 screws The last picture is of the metal connectors that attach it to the display assembly. The last picture is of the metal connectors that attach it to the display assembly.
  • Take the screen off the metal connectors by unscrewing each side. Each side has 2 screws
  • The last picture is of the metal connectors that attach it to the display assembly.
The huge wire on the back of the screen is for both the webcam/microphone, as well as the screen. Detach the cable from the screen. It is connected under the foil flap. Detach the cable from the screen. It is connected under the foil flap.
  • The huge wire on the back of the screen is for both the webcam/microphone, as well as the screen.
  • Detach the cable from the screen. It is connected under the foil flap.
After removing the cable from the back of the screen, detach the webcam assembly. After removing the cable from the back of the screen, detach the webcam assembly.
  • After removing the cable from the back of the screen, detach the webcam assembly.
alea
Membre depuis le 06/10/2010
1 242 Réputation
19 tutoriels rédigés
Équipe
Cal Poly, Team 22-2, Maness Fall 2010 Membre de l'équipe Cal Poly, Team 22-2, Maness Fall 2010
CPSU-MANESS-F10S22G2
6 membres
20 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 8
Total : 4,333
