Pièces
Aucune pièce nécessaire.
Make sure the device is unplugged before continuing.
  • Make sure the device is unplugged before continuing.
  • Use a Phillips size 2 screwdriver to remove the four 12mm screws found on the bottom of the machine.
Ajouter un commentaire
Remove the single black Phillips size 0 10mm length screw on the back of the machine.
  • Remove the single black Phillips size 0 10mm length screw on the back of the machine.
Remove the bottom cover from the machine and slide it down the power cord.
  • Remove the bottom cover from the machine and slide it down the power cord.
Remove the three 60mm Phillips size 0 screws holding the top cover on.
  • Remove the three 60mm Phillips size 0 screws holding the top cover on.
Remove the top cap of the machine by turning it in a counter-clockwise motion.
  • Remove the top cap of the machine by turning it in a counter-clockwise motion.
What about the steamer wand? How does that come off?
scottevil - Réponse
Wondering the same thing myself....
bhlavin - Réponse
This is the most important step: and has been left unexplained!
Philip Welch - Réponse
There's a different set of instructions elsewhere on this site to remove the steam wand
Eunice Price - Réponse
Remove the grey plastic ring from the rim of the filter basket holder.
  • Remove the grey plastic ring from the rim of the filter basket holder.
Lift and remove the top black plastic cover from the machine.
  • Lift and remove the top black plastic cover from the machine.
3 autre(s) ont terminé cette réparation.
Wyatt Hall
Membre depuis le 13/10/2014
812 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 6-25, Maness Fall 2014 Membre de l'équipe Cal Poly, Team 6-25, Maness Fall 2014
CPSU-MANESS-F14S6G25
4 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 34
Total : 1,111
