Aller au contenu principal
Disassembling Macintosh IIsi Floppy Drive
Ce dont vous avez besoin
  1. Disassembling Macintosh IIsi Floppy Drive, Top Case: étape 1, image 1 de 2 Disassembling Macintosh IIsi Floppy Drive, Top Case: étape 1, image 2 de 2
    • Start by turning the computer around, and remove this #0 Phillips Screw.
    • There may or may not be a Phillips #0 screw here, depending on whether or not the computer has ever been serviced.
  2. Disassembling Macintosh IIsi Floppy Drive: étape 2, image 1 de 3 Disassembling Macintosh IIsi Floppy Drive: étape 2, image 2 de 3 Disassembling Macintosh IIsi Floppy Drive: étape 2, image 3 de 3
    • Now lift these two clips, and slowly pivot the case up.
    • You can now seperate the top of the computer from the rest of the machine.
  3. Disassembling Macintosh IIsi Floppy Drive, Floppy Drive: étape 3, image 1 de 3 Disassembling Macintosh IIsi Floppy Drive, Floppy Drive: étape 3, image 2 de 3 Disassembling Macintosh IIsi Floppy Drive, Floppy Drive: étape 3, image 3 de 3
    • The "SuperDrive" is mounted similarly to the hard drive, and positioned right next to it.
    • Push these two tabs out, and lift the drive up.
  4. Disassembling Macintosh IIsi Floppy Drive: étape 4, image 1 de 3 Disassembling Macintosh IIsi Floppy Drive: étape 4, image 2 de 3 Disassembling Macintosh IIsi Floppy Drive: étape 4, image 3 de 3
    • Flip the drive so it is on top of the power supply, and remove the "Red-Ribbon" cable.
    • 1.44MB floppy drives need a ribbon cable with a red stripe on one side. 400KB floppy drives use a ribbon cable with a yellow stripe on one side. 800KB floppy drives can use a red, or yellow striped cable.
    • This drive was manufactured by Sony in 1990.
2 autres ont terminé cette réparation.
Chris Green
Membre depuis le 10/11/09
36 978 Réputation
49 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
322 membres
2 519 tutoriels rédigés
Un commentaire
Hi there, I have IIsi Mac but the driver couldn’t read all the floppy dsks!
note: it was stored for more than 7 years.
Q. How can I clean it and what is the suitable cleaning items you recommend?
thanks.
Abdulaziz - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 2,758
