Aller au contenu principal
Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case
Ce dont vous avez besoin
  1. Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case, Case: étape 1, image 1 de 2 Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case, Case: étape 1, image 2 de 2
    • Turn the speaker face down, so the connector side is up.
    • Remove the four #2 Philips screws on the back plate.
  2. Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case: étape 2, image 1 de 1
    • Remove the foam insert to expose the two spade connectors.
    • Carefully separate the connectors
  3. Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case: étape 3, image 1 de 2 Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case: étape 3, image 2 de 2
    • Turn the speaker so the grill side is up.
    • Remove the four screws on the grill. I had to use a t-10 Torx bit to remove them.
    • The grill is not glued on, but may require a bit of prying to remove.
  4. Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case: étape 4, image 1 de 2 Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case: étape 4, image 2 de 2
    • Remove the four silver bolts holding the speaker in place. These bolts also have threads inset for the grill screws to fit into.
    • This is a pretty quick and easy teardown, not too many parts in this one. The meyer speaker's part number is ST-164. It's a 16 Ohm driver.
4 autres ont terminé cette réparation.
RoggeSound
Membre depuis le 06/05/10
2 345 Réputation
1 tutoriel rédigé
2 commentaires
So I took one of my MM-4 apart because something was rattling. Turns out it has a loose magnet assembly. It must have been dropped in shipping.
Garrett McWilliams - Réponse
Do you by any chance still have it?
I have two of them already and with some zipties and rubber they sound great again…
Would you by any chance ship the broken driver over to me?
Jan Marius -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 9
Total : 6,749
