Introduction
This is ONLY a prerequisite guide to remove the LCD shield plate in the Motorola Cliq.
Turning over your phone, place two fingers on the back cover and apply pressure away from the camera to slide the back cover off. Turning over your phone, place two fingers on the back cover and apply pressure away from the camera to slide the back cover off.
  • Turning over your phone, place two fingers on the back cover and apply pressure away from the camera to slide the back cover off.
Ajouter un commentaire
Pinch the battery pull tab located below the camera, pull it upwards, and remove the battery. The pull tab may be tucked under the battery.
  • Pinch the battery pull tab located below the camera, pull it upwards, and remove the battery.
    • The pull tab may be tucked under the battery.
Wedge a plastic opening tool behind the panel covering the camera, pry it up, and remove it using your fingers. The panel is held down by adhesive and may require you to wedge and pry the right side of the panel before it can be easily removed. The panel is held down by adhesive and may require you to wedge and pry the right side of the panel before it can be easily removed.
  • Wedge a plastic opening tool behind the panel covering the camera, pry it up, and remove it using your fingers.
    • The panel is held down by adhesive and may require you to wedge and pry the right side of the panel before it can be easily removed.
Remove the six 4.0 mm T4 Torx screws which line the edge of the back of the phone.
  • Remove the six 4.0 mm T4 Torx screws which line the edge of the back of the phone.
Turn the phone over and slide out the keyboard. Wedge a plastic opening tool where the keyboard meets the back casing of the phone next to the headphone jack. Carefully pry open the back casing along the keyboard's edge until at least two corners of the back casing are separated from the keyboard.
  • Turn the phone over and slide out the keyboard.
  • Wedge a plastic opening tool where the keyboard meets the back casing of the phone next to the headphone jack.
  • Carefully pry open the back casing along the keyboard's edge until at least two corners of the back casing are separated from the keyboard.
    • Do not fully separate the rear panel from the phone. A cable is connecting the two parts together.
Carefully separate the back casing from the rest of the phone.
  • Carefully separate the back casing from the rest of the phone.
Gently pry ZIF connector upwards using the flat end of a spudger tool. The ZIF connector is glued down. Be gentle! Ripping it off or breaking it will make your phone inoperable.
  • Gently pry ZIF connector upwards using the flat end of a spudger tool.
    • The ZIF connector is glued down. Be gentle! Ripping it off or breaking it will make your phone inoperable.
    • You may need adhesive to keep your power cable in place when reassembling your phone.
Press your thumb against the orange power cable and pull it down slowly to disconnect the power cable from the bottom of the keyboard. The rear casing and the rest of the phone should now be completely separated. The rear casing and the rest of the phone should now be completely separated.
  • Press your thumb against the orange power cable and pull it down slowly to disconnect the power cable from the bottom of the keyboard.
  • The rear casing and the rest of the phone should now be completely separated.
Wedge the plastic opening tool underneath the black display connector and pry it off its socket on the motherboard. Wedge the plastic opening tool underneath the black display connector and pry it off its socket on the motherboard.
  • Wedge the plastic opening tool underneath the black display connector and pry it off its socket on the motherboard.
Pry the orange keyboard connector from its socket on the motherboard using the edge of the plastic opening tool. Pry the orange keyboard connector from its socket on the motherboard using the edge of the plastic opening tool.
  • Pry the orange keyboard connector from its socket on the motherboard using the edge of the plastic opening tool.
Carefully grab the sides of the motherboard with your fingers and remove it from the phone. Carefully grab the sides of the motherboard with your fingers and remove it from the phone. Carefully grab the sides of the motherboard with your fingers and remove it from the phone.
  • Carefully grab the sides of the motherboard with your fingers and remove it from the phone.
Remove the ten 3.0 mm T4 Torx screws near the black display cable.
  • Remove the ten 3.0 mm T4 Torx screws near the black display cable.
Orient the phone so that the edge closest to the camera points towards you and slide out the keyboard. Wedge the tip of a spudger between the keyboard and the display assembly below the camera. With steady pressure, pry the keyboard away from the display assembly.
  • Orient the phone so that the edge closest to the camera points towards you and slide out the keyboard.
  • Wedge the tip of a spudger between the keyboard and the display assembly below the camera.
  • With steady pressure, pry the keyboard away from the display assembly.
    • The keyboard and display assembly are glued together, so expect some resistance.
    • Do not completely separate the keyboard and display assembly because the display flex cable still connects them.
Grab the display flex cable and gently push it through the notch it is coming out of. Grab the display flex cable and gently push it through the notch it is coming out of. Grab the display flex cable and gently push it through the notch it is coming out of.
  • Grab the display flex cable and gently push it through the notch it is coming out of.
Wedge a plastic opening tool underneath one of the metal panels on the underside of the display assembly. Pry upwards and remove the metal panel. Repeat this step for the second metal panel located on the opposite side of the phone.
  • Wedge a plastic opening tool underneath one of the metal panels on the underside of the display assembly.
  • Pry upwards and remove the metal panel.
  • Repeat this step for the second metal panel located on the opposite side of the phone.
Remove the four 3.0 mm T4 Torx screws at the corners of the phone.
  • Remove the four 3.0 mm T4 Torx screws at the corners of the phone.
Wedge a plastic opening tool between the edge and the black pastic cover on the underside of the display assembly. Run the plastic opening tool along the edges to separate the black plastic cover from the display assembly. Remove the black plastic cover.
  • Wedge a plastic opening tool between the edge and the black pastic cover on the underside of the display assembly.
  • Run the plastic opening tool along the edges to separate the black plastic cover from the display assembly.
  • Remove the black plastic cover.
Remove the six 3.0 mm T4 Torx screws that align on the phone's sides.
  • Remove the six 3.0 mm T4 Torx screws that align on the phone's sides.
Insert a plastic opening tool between the LCD shield plate and a corner of the keyboard slider plate. Pry apart the keyboard slider plate and LCD shield plate.
  • Insert a plastic opening tool between the LCD shield plate and a corner of the keyboard slider plate.
  • Pry apart the keyboard slider plate and LCD shield plate.
    • Do not completely separate them: the keyboard slider plate is still connected to the LCD shield plate via the display flex cable.
Pry the display flex cable from its connector on the LCD shield plate with a plastic opening tool. Separate the display flex cable from the LCD cover plate.
  • Pry the display flex cable from its connector on the LCD shield plate with a plastic opening tool.
  • Separate the display flex cable from the LCD cover plate.
Tony Tran
Membre depuis le 14/04/2013
64 Réputation
8 tutoriels rédigés
Équipe
Cal Poly, Team 10-42, Amido Spring 2013 Membre de l'équipe Cal Poly, Team 10-42, Amido Spring 2013
CPSU-AMIDO-S13S10G42
4 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 298
