Introduction
Reception issues or a broken antenna may mean the antenna needs to be replaced. In this guide, you are going to:
  • Access the antenna
  • Remove the antenna
NOTE: This guide shows the E815 partially dissembled. Disassembly is not required to access the antenna.
Outils
Aucun outil requis.
Locate the antenna port on the top of the phone.
  • Locate the antenna port on the top of the phone.
Removing Antenna Only
Zoie E - Réponse
Grip the plastic support post and unscrew the apparatus using a counterclockwise twist. Pull the apparatus up and out of the phone.
  • Grip the plastic support post and unscrew the apparatus using a counterclockwise twist.
  • Pull the apparatus up and out of the phone.
Ajouter un commentaire
Zoie E
Membre depuis le 12/01/2011
595 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 14-8, Forte Winter 2011 Membre de l'équipe Cal Poly, Team 14-8, Forte Winter 2011
CPSU-FORTE-W11S14G8
5 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 4
Total : 1,970
