Aller au contenu principal
Disassembling Motorola i850 LCD Board
Ce dont vous avez besoin
  1. Disassembling Motorola i850 LCD Board, LCD Board: étape 1, image 1 de 1
    • Open the flip cover of the phone with the LCD screen facing towards you.
  2. Disassembling Motorola i850 LCD Board: étape 2, image 1 de 2 Disassembling Motorola i850 LCD Board: étape 2, image 2 de 2
    • Use a Razor Blade to remove the screw covers.
    • Razor Blade is very sharp. Use caution.
  3. Disassembling Motorola i850 LCD Board: étape 3, image 1 de 1
    • Unscrew the screws using a Phillips #00 Screwdriver.
  4. Disassembling Motorola i850 LCD Board: étape 4, image 1 de 1
    • Insert a Spudger into the side crack of the flip cover and slowly separate the phone cover from the case.
  5. Disassembling Motorola i850 LCD Board: étape 5, image 1 de 1
    • Gently separate the flip cover case from the phone with your hands when the crack is wide enough.
  6. Disassembling Motorola i850 LCD Board: étape 6, image 1 de 1
    • Partially close the flip cover of the phone in order to take off the outer case.
  7. Disassembling Motorola i850 LCD Board: étape 7, image 1 de 1
    • Completely remove the outer casing from the phone.
  8. Disassembling Motorola i850 LCD Board: étape 8, image 1 de 2 Disassembling Motorola i850 LCD Board: étape 8, image 2 de 2
    • Place your thumb underneath the protective metal covering to remove it from the phone.
  9. Disassembling Motorola i850 LCD Board: étape 9, image 1 de 1
    • Gently detach the black microchip from the phone with a Tweezer.
  10. Disassembling Motorola i850 LCD Board: étape 10, image 1 de 1
    • Prop out the LCD board from the phone using your fingertips.
  11. Disassembling Motorola i850 LCD Board: étape 11, image 1 de 2 Disassembling Motorola i850 LCD Board: étape 11, image 2 de 2
    • Remove the LCD board from the phone by grabbing the bottom side of the LCD board.
Andrew Aw
Membre depuis le 04/08/10
1 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 34-56, Forte Spring 2010 Membre de l'équipe Cal Poly, Team 34-56, Forte Spring 2010
CPSU-FORTE-S10S34G56
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 2,326
