Introduction
This guide details how to remove the internal backplate to expose the speaker, the headphone jack, and the logic board.
Slide the notch downward while pulling the back cover off to remove it. Slide the notch downward while pulling the back cover off to remove it. Slide the notch downward while pulling the back cover off to remove it.
  • Slide the notch downward while pulling the back cover off to remove it.
Ajouter un commentaire
Use your fingers to push the battery upward from the bottom. Lift upwards to remove the battery. Lift upwards to remove the battery.
  • Use your fingers to push the battery upward from the bottom.
  • Lift upwards to remove the battery.
Unscrew the antenna in a counter-clockwise fashion. Remove the aluminum cover.
  • Unscrew the antenna in a counter-clockwise fashion.
  • Remove the aluminum cover.
Unscrew the 3 screws shown. Lift up the right part of the Nextel logo and unscrew the screw underneath. Lift up the right part of the Nextel logo and unscrew the screw underneath.
  • Unscrew the 3 screws shown.
  • Lift up the right part of the Nextel logo and unscrew the screw underneath.
DO NOT force the cover off as it could damage the ribbon cable! Gently lift the back cover off.
  • DO NOT force the cover off as it could damage the ribbon cable!
  • Gently lift the back cover off.
Carefully pry off the connection between the headphone jack and logic board. Carefully pry off the connection between the headphone jack and logic board. Carefully pry off the connection between the headphone jack and logic board.
  • Carefully pry off the connection between the headphone jack and logic board.
Grant Glazebrook
Membre depuis le 14/04/2010
7 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 29-61, Johann Spring 2010 Membre de l'équipe Cal Poly, Team 29-61, Johann Spring 2010
CPSU-JOHANN-S10S29G61
4 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 1,241
