Aller au contenu principal
Disassembling Nokia 3100b Microphone
Ce dont vous avez besoin
  1. Disassembling Nokia 3100b Microphone, Battery: étape 1, image 1 de 1
    • Make sure your phone is turned off.
  2. Disassembling Nokia 3100b Microphone: étape 2, image 1 de 1
    • Press the button on the back of the phone and slide the back panel off.
    • Remove the battery by pulling it from the phone.
  3. Disassembling Nokia 3100b Microphone, SIM Card: étape 3, image 1 de 1
    • Gently pull back the small metal frame holding the SIM card into place, and lift open the frame.
  4. Disassembling Nokia 3100b Microphone: étape 4, image 1 de 1
    • Retrieve your SIM card.
  5. Disassembling Nokia 3100b Microphone, Microphone: étape 5, image 1 de 1
    • Press the black tabs to release the front cover from the phone.
  6. Disassembling Nokia 3100b Microphone: étape 6, image 1 de 1
    • Remove the front cover from the phone.
    • Set the front cover, as indicated, aside.
  7. Disassembling Nokia 3100b Microphone: étape 7, image 1 de 1
    • Remove the screws as they are indicated in the order of the colors of the rainbow. (Red, Orange, Yellow, Green, Blue, Purple.)
  8. Disassembling Nokia 3100b Microphone: étape 8, image 1 de 1
    • Remove the screen assembly from the phone base.
    • Set the screen assembly aside.
  9. Disassembling Nokia 3100b Microphone: étape 9, image 1 de 1
    • Note the location of the microphone.
  10. Disassembling Nokia 3100b Microphone: étape 10, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Use tweezers to remove the microphone from the phone's base.
  11. Disassembling Nokia 3100b Microphone: étape 11, image 1 de 1
    • The microphone is now removed.
Sterling Fuentes
Membre depuis le 04/09/10
130 Réputation
8 tutoriels rédigés
Équipe
Cal Poly, Team 29-64, Johann Spring 2010 Membre de l'équipe Cal Poly, Team 29-64, Johann Spring 2010
CPSU-JOHANN-S10S29G64
3 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 16
Total : 2,095
