Aller au contenu principal
Disassembling Nokia 3100b Speaker
Ce dont vous avez besoin
  1. Disassembling Nokia 3100b Speaker, Battery: étape 1, image 1 de 1
    • Make sure your phone is turned off.
  2. Disassembling Nokia 3100b Speaker: étape 2, image 1 de 1
    • Press the button on the back of the phone and slide the back panel off.
    • Remove the battery by pulling it from the phone.
  3. Disassembling Nokia 3100b Speaker, SIM Card: étape 3, image 1 de 1
    • Gently pull back the small metal frame holding the SIM card into place, and lift open the frame.
  4. Disassembling Nokia 3100b Speaker: étape 4, image 1 de 1
    • Retrieve your SIM card.
  5. Disassembling Nokia 3100b Speaker, Screen: étape 5, image 1 de 1
    • Separate the front cover from the main body of the phone.
  6. Disassembling Nokia 3100b Speaker: étape 6, image 1 de 1
    • Remove the six screws along the edges of the phone.
  7. Disassembling Nokia 3100b Speaker: étape 7, image 1 de 1
    • Pull the screen assembly from the base of the phone.
  8. Disassembling Nokia 3100b Speaker: étape 8, image 1 de 1
    • Carefully lift the keypad portion of the screen assembly from the circuit board.
  9. Disassembling Nokia 3100b Speaker: étape 9, image 1 de 1
    • Separate the screen from the circuit board.
    • Reconnect the ports during reassembly or the screen will not function properly.
    • Remember to reconnect the screen to the circuit board when reassembling!
  10. Disassembling Nokia 3100b Speaker: étape 10, image 1 de 1
    • Gently push down on the screen to pop it off of the assembly.
  11. Disassembling Nokia 3100b Speaker: étape 11, image 1 de 1
    • When the screen falls out the assembly, two white tabs will fall out with it.
    • When reinstalling the screen, insert the tabs with the slanted side pointing upwards so they slide into the assembly.
  12. Disassembling Nokia 3100b Speaker, Speaker: étape 12, image 1 de 1
    • Set the screen and the tabs aside.
  13. Disassembling Nokia 3100b Speaker: étape 13, image 1 de 1
    • You can now access the speaker.
    • Note the tab on the end of the speaker. It must be placed in correctly in order to reinstall the speaker.
  14. Disassembling Nokia 3100b Speaker: étape 14, image 1 de 1
    • Remove the speaker from the assembly.
Sterling Fuentes
Membre depuis le 04/09/10
130 Réputation
8 tutoriels rédigés
Équipe
Cal Poly, Team 29-64, Johann Spring 2010 Membre de l'équipe Cal Poly, Team 29-64, Johann Spring 2010
CPSU-JOHANN-S10S29G64
3 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 1,163
